Old 09-26-2017, 12:49 PM   #1
James L Miller
Liked 25 Times in 16 Posts
Default SVL Gears
I was looking at DANA 60 gears on the Summit site and they have a brand called SVL that are less expensive than the other brands. Has anyone bought this brand and had good service life with them? I'm assuming they are made in China, but don't know that for sure. Here is the description on the Summit page:
"SVL Drivetrain ring and pinion gear sets make finding the right ratio for your application easy. Engineered and manufactured for all makes and ratios, they deliver the ideal blend of coverage, performance, and value. SVL starts their ring and pinion sets with a computer-generated gear summary. From there, the gearing is forged from alloy steel for optimal hardness, and then the gears are cut with the utmost accuracy to ensure the smoothest possible ride, and computer-controlled heat-treating results in extra wear resistance. In the final stage of the process, the ring gear is mated to the pinion through gear lapping, which provides ideal meshing of the gearing. You can count on SVL Drivetrain ring and pinion gear sets to fit and function as expected in your automotive application."
Mopar 2 Ya!
Old 09-26-2017, 02:44 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: SVL Gears
SVL is really Dana. I am not sure if its a separate company or that is just the name that Dana and or Spicer use for the gears they sell now.
My son got a set for a Dada 60 he is building. No complaints from the guy that set them up but he has not actually used them yet.
Bill
Old 09-26-2017, 03:37 PM   #3
HIGHOCTAIN2000
Just installed my first set instalation went well and gears are quiet box said made in india will see how long they last
HIGHOCTAIN2000 is offline   Reply With Quote
Old 09-26-2017, 08:07 PM   #4
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
I'm lead to understand that most of today's gear sets are manufactured in India or Malaysia.
Dave Turner
SS/GT #1153
Old 09-27-2017, 01:03 PM   #5
bob shirley
motive gears are now made in Italy. good quality on new tooling
bob shirley is offline   Reply With Quote
Old 09-27-2017, 07:59 PM   #6
James L Miller
Italy should know how to make gears since they have about 20 in each Ferrari engine with all the cam drive gears. Thanks to everyone for the input.
Mopar 2 Ya!
Old 09-27-2017, 08:09 PM   #7
David Lee
Liked 346 Times in 126 Posts
are you going to the dana since mopar 8 3/4 gears are no longer available?
Old 09-28-2017, 11:36 PM   #8
James L Miller
My 1964 Belvedere already has a DANA 60 in it, no gears or spool in it now. I have some 5.13 and 5.38 gears and a spool for it. It's taking MCH forever on the SS Hemi heads, so thinking about a BBM to run in NSS for the time being. Maybe 4.88s? I have a set of 4.56 gears (Richmond) that I bought on a MP clearance sale many years back.
On the 1966 Dart, I think the 8-3/4" and a 904 ought to be OK with a 273-2bbl powerhouse. I have a new set of 4.56s (new Richmond) and a used set of 5.13s I bought from Terry Dye a month or so ago. Gear selection for both is getting worse. I don't see any 5.57 gears for the DANA 60 anymore.
Mopar 2 Ya!
