Liked 64 Times in 27 Posts
Putting a stick in my Drag Pak this winter, who has the best clutch setup? Best transmission? Looking at G-Force for the transmission, any thoughts on this?
Dennis Breeden FSS/K |
Liked 1,877 Times in 422 Posts
If you want something affordable, reliable, consistent, and easy to work with, a Jerico DR4.4, a McLeod SoftLock, and a QuickTime bellhousing. Might not be the absolute fastest. But it will go rounds, and won't cost you your life savings.
Alan Roehrich 212A G/S |
Thanks Alan, I appreciate the advice. I really don't want something I have to constantly repair. Going to be a challenge I'm sure.
Great advice. Call Cale Aronson at Black Magic Clutches, he can help you with a clutch setup and data. He also has clutch tuning seminars.
Todd Greene |
Liked 242 Times in 81 Posts
Rob Youngblood at Advanced Clutches 208-880-6214 nobody better. Great personal service always there to help and answer questions and make your car quicker. Don't believe me ask Bob Gullet.
P.S. you might be surprised at how easy it is to run a clutch car.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. Last edited by Rod Greene; 10-03-2017 at 09:33 PM. |
Liked 1,439 Times in 301 Posts
I love the Jerico', but I think the G101 is worth a look as well. It has bearing supports between third and fourth and is strong. The soft locks are good for basic ops. I would say most single ten inch have a big tuning window. I prefer a dual 7 Youngblood. Easy to tune and you can tighten it up so it doesn't wear a lot.
The two things that get newbies in trouble. 1) not having enough clearance between the fingers and the throwout bearing 2) the burnout Make sure you work out hand signals with a crew person in case you need to abort thre burnout. Make sure the tires have some water on them. Get the rpm up enough to snap the tires loose in the water. Don't ever shift in the water unless you race a true clutchless trans. i,e. Liberty Equalizer or GF2000 etc. It is more fun than you can believe! Good Luck!
James Schaechter 3163 STK |
Liked 693 Times in 205 Posts
I have seen more racers have problems with Jerico's this year and also having issues with the new ownership getting parts. The G Force might be a better way to go.
Liked 91 Times in 29 Posts
Anyone know the weight differences between the jerico and g-force.
Bruce Cameron 68 Nova E/S 68 Camaro SS/I or ? |
Liked 10,819 Times in 2,248 Posts
I would talk to Luke and Kevin!
Liked 502 Times in 130 Posts
Get in touch with the other SS stick racers.
For my stocker DP, I went the 3 run old DR4(found one that actually only had 3 runs) and sof lok route for my dragpak. But its a stocker. I kept all the auto stuff just in case I didn't like it, or we couldn't get it to work. Superstocker to be fast, and if you have to be fast, Best to budget 2X what you think it will cost. Making it fit takes fabrication and time. Fastest stick parts can cost a lot, 2-3 times what the auto does. Up to you how fast you need/want to be. Think Comp cost. Basics: First thing first, you will need a racepak with driveshaft sensor, and get the tranny imput sensor install option for whatever tranny you get...... From the seat, driving through the clutch and slipping the tires, can feel exactly the same and gave me the same 60 foots! Liberty is closest to you in Indiana, and they do some truly bomb proof trannys. Since you will be spending the coin on a 5 speed, I don't see any used libertys ever on the market, Gforce is a good choice too in PA, Jerico, I don't know too much about their 5 speeds. Go visit if you can. Clutchless versus clutch assisted will be a consideration too, clutchless is faster more $ Bellhousing..... browell aluminum with the adjustment window is in your state. Enough said. Clutch single versus multi, size, need to figure that out for your bellhousing and how fast you need to be. Thats a good starting list, others with more knowledge and experience than me will chime in. Eric For
Eric Merryfield 1883 STK |
