#21 | |
Liked 269 Times in 99 Posts
There was talk of air and electric shifters being used in stockers stretching the rule so there is a decision made on that. The new rule does state OEM Electronic Shift. How do you interpret it? Electronic rpm controls for the electric (internal or external to the transmission) shifting of OEM electric shift automatic transmissions permitted in computer controlled vehicles only. My assumption is Mr. Forte will have some input on this.
#22 |
[QUOTE=SS3718;549006]Michael,
Some of the bracket races I've watched here lately doesn't appear to have any rules when it comes to safety....helmet mandatory, everything else is optional. It's not my style but it also doesn't directly impact me! If you want the simplest rule when it comes to safety....everyone should wear the same thing and have the same requirements. After all, your 10.50 car is running against 8.50 cars going 160+. Nick[/QUOTE Agree on both points. I know of some late model street driven Corvettes, one that runs low 11's and another running low 10's that have done so with just a seat belt and helmet.
Bob Schmalz 3199 Stock |
#23 |
Liked 13 Times in 9 Posts
Oh. You guys are totally right. Because some bracket race not operated directly by NHRA doesn't enforce the rules, that means that NHRA National and Divisional events cannot and should not be enforced...
#24 |
Liked 225 Times in 88 Posts
Ok . So what do some of you guys run now on 350 & 400 for shields and did you have floor pan clearance issues ? My friends superstreet car runs a shield on its powerglide... I can the trans blanket is the cheap way out and it would be so dirty after 2 years its trash any how , plus no floor pan issues .......The rule didn't say auto trans only just 10;99 ! Are the stick cases sfi ? Like the ATI TH400,s on the new factory cars .
#25 |
After reading it again its under automatic only .
#26 |
Liked 237 Times in 126 Posts
Anyone remember Bonzi starts from the 60s? Rev up with the trans in neutral and punch the button on the green light. Saw a stock 442 destroy a trans at Milan when I was in High School and the "staff photographer". Broke the driver's foot and put him in the hospital.
I run an SFI bellhousing and hard trans shield on my 302 C4 12 second bracket car. They call an automatic a slush box but it's really more of a shrapnel box if all that spinning steel ever takes a hike. On the original topic, I don't care for the spread in safety across cars in the same category. A stocker with a roll bar is often chased by a much faster car with a 25.5 cage. This is fine as long as they stay in their own lanes but this isn't a given. If a COPO or CJ gets loose in the lights, the T/SA would be the big looser.. Just a thought.
#27 | |
If it's the latter, or anything similar, the reason should be obvious If you're comparing 2 of the same car then I don't have any ideas. Sorry. |
#28 | |
275hp EFI 360 in my Volare, FGT requires full cage, -5 suit, etc... all of the 9.99-quicker requirements but at ANY E.T.
#29 | |
Liked 239 Times in 114 Posts
#30 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
