Old 11-06-2017, 01:03 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default 83' Camaro Top Strut Mount.
I noticed the rubber bushing in my top strut mount( camber plate? ) is cracked and falling apart. My search at the junkyard turned up 8 that were in worse shape than mine. Found some in the shed that are in good shape but brings up the question, is an aftermarket piece available or is there a way to eliminate the rubber altogether? Junkyard parts are getting harder to find for these cars. I use an old set of Koni struts up front. Thanks in advance guys.
brian schuetta is offline   Reply With Quote
Old 11-06-2017, 02:02 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 83' Camaro Top Strut Mount.
One option, the factory replacement upper mounts are still available. Check your local parts store for Moog or other brands.
Larry Woodfin 471W
Old 11-06-2017, 02:05 PM   #3
Dragsinger
another option, Racecraft
http://www.racecraft.com/index.php?m...roducts_id=351
Larry Woodfin 471W
Old 11-06-2017, 02:30 PM   #4
Jeff Niceswanger
Liked 1,069 Times in 377 Posts
If you go with OEM, I believe the Z-28's and IROC's had a bearing, where the cheaper models had a bushing ...
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 11-06-2017, 03:19 PM   #5
brian schuetta
Jeff, will check that out. I don't remember seeing that before but will check, have access to many examples. The ones I dug out of the shed have bushings. Will price new pieces also. Nice Kit shown there, maybe in the spring time.
Old 11-06-2017, 04:35 PM   #6
FED 387
Liked 335 Times in 182 Posts
look on eBay top strut mount plates lots of the with the bearing no bushing about $55-75 per pair---Fed 387
Old 11-08-2017, 10:30 PM   #7
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
We use RaceCraft on all the 82-92 Camaro that we install Santhuff Struts on. The work great.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 11-09-2017, 11:24 AM   #8
brian schuetta
The Racecraft setup can be used with any strut right?
Old 11-09-2017, 08:07 PM   #9
Eman
Liked 133 Times in 76 Posts
I don't know if the aftermarket upper strut mounts are legal in stock or super stock as I'm just a bracket racer. I have had your exact problem and bought a nice set on ebay that work with factory struts and aftermarket replacements. They are all steel and can accept a coilover also. They have 2 sets of adjustments and give you more caster.
https://hotpart.com/product/camarofi...ucts-made-usa/
These are what I have.
Old 11-09-2017, 10:06 PM   #10
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Never say " just a bracket racer "... ha ha because that what most of these guys are once eliminations start , unless a heads up situation arises ...
