Liked 28 Times in 15 Posts
I noticed the rubber bushing in my top strut mount( camber plate? ) is cracked and falling apart. My search at the junkyard turned up 8 that were in worse shape than mine. Found some in the shed that are in good shape but brings up the question, is an aftermarket piece available or is there a way to eliminate the rubber altogether? Junkyard parts are getting harder to find for these cars. I use an old set of Koni struts up front. Thanks in advance guys.
Liked 99 Times in 60 Posts
One option, the factory replacement upper mounts are still available. Check your local parts store for Moog or other brands.
Larry Woodfin 471W |
Liked 1,034 Times in 368 Posts
If you go with OEM, I believe the Z-28's and IROC's had a bearing, where the cheaper models had a bushing ...
Jeff Niceswanger 3740 SS |
Jeff, will check that out. I don't remember seeing that before but will check, have access to many examples. The ones I dug out of the shed have bushings. Will price new pieces also. Nice Kit shown there, maybe in the spring time.
Liked 333 Times in 180 Posts
look on eBay top strut mount plates lots of the with the bearing no bushing about $55-75 per pair---Fed 387
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
We use RaceCraft on all the 82-92 Camaro that we install Santhuff Struts on. The work great.
Marty Rinehart Jr 1125 SS STK SG SC SST |
The Racecraft setup can be used with any strut right?
Liked 133 Times in 76 Posts
I don't know if the aftermarket upper strut mounts are legal in stock or super stock as I'm just a bracket racer. I have had your exact problem and bought a nice set on ebay that work with factory struts and aftermarket replacements. They are all steel and can accept a coilover also. They have 2 sets of adjustments and give you more caster.
https://hotpart.com/product/camarofi...ucts-made-usa/ These are what I have. |
Liked 482 Times in 159 Posts
Never say " just a bracket racer "... ha ha because that what most of these guys are once eliminations start , unless a heads up situation arises ...
