Old 11-21-2017, 09:12 PM   #1
Dave1695
Liked 15 Times in 11 Posts
Default a lighter battery
I'm going to need a new battery for my 67 Camaro Stocker next year. Want to shed some front end weight; is there a light weight, 12 volt battery on the market that is better than the rest?
Dave1695 is offline   Reply With Quote
Old 11-22-2017, 12:38 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: a lighter battery
Don't know about better than the rest, but we have used this Braille for over three years now without issue in our E/SA '67 Camaro.
https://www.braillebattery.com/index...atteries/b3121
Rich Taylor
I/SA - 321
Old 11-22-2017, 02:01 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Batterymart.com
Odyssey brand non MJ (Metal Jacket) style are lighter. A PC925 actually weighs 24lbs not the advertised 26, that's with the box for shipping. $154 shipped. I have been running these for the past 10 years without a failure and replace them every 2 years as a maintenance item.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 11-22-2017, 10:59 PM   #4
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
If you wanted to lose a LOT of weight you could go with a Lithium battery. Pretty spendy at $379, but it only weighs 4 pounds! Made in Colorado.
http://www.batterymart.com/p-ltx680-...0-battery.html
Larry Merk
Larry Merk is offline   Reply With Quote
Old 11-23-2017, 12:30 AM   #5
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Funny how lithium batteries are so dangerous in airplanes but this battery is advertised as being for experimental aircraft.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 11-23-2017, 12:58 AM   #6
HandOverFist
Experimental coincide with expendable?
Rich Taylor
I/SA - 321
Old 11-23-2017, 05:15 AM   #7
Dickens
Liked 12 Times in 8 Posts
I use a wheel chair battery that is dimensionally small and has quick recharge
Interstate batteries 35 AH rating 22 pounds
DD
Has been in 3 seasons
Dickens is offline   Reply With Quote
Old 11-23-2017, 09:11 AM   #8
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
I mounted a Braille in our Dakota Stocker this time last year and it worked fine this summer in some higher than normal summer days - the only thing I noticed with it was I had to continually tighten the top post adapters all summer till they finally seemed to seat but over all between tire/wheel combo and the battery we moved 44 lbs - just my $.02
BA1927 is offline   Reply With Quote
Old 11-24-2017, 09:39 AM   #9
Chris1529
Liked 70 Times in 29 Posts
Originally Posted by Sean Marconette View Post
Batterymart.com
Sean
Do you charge between rounds or run alternator? Do you use an Odyssey charger or another brand of charger?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 11-24-2017, 10:16 AM   #10
Coleydog
Liked 53 Times in 38 Posts
I have a friend who sells and uses this type in his top sportsman car (830 ci) one starts the engine the other runs the electronics. Never a problem with either. He said he would sell me one at cost when I'm ready to buy. About 4x5x5. After three seasons still good. He powers his AC and lights in his trailer using a bank of them with an inverter. Solar panels on the roof to recharge. He owns and runs a motor home-trailer business.
Mike
