Old 11-23-2017, 10:48 PM   #1
Nmbr1GMfan
Default Shock options?
'76 nova with Lakewood 90/10 fronts and Calvert rear shocks. Santuff's are on the bottom of the list, just too much $$ for a cheap car. What are some options that are better than what I have? Thanks in advance.
Todd Greene
Old 11-24-2017, 09:12 AM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Shock options?
I would suggest you stay with the rear Calverts and upgrade the fronts. Look for a double adjustable. You will want it soft on the rebound but very stiff on compression to control bounce from launch and gear changes. Consider Afco, they use a single knob on bottom for compression and you adjust rebound through upper shaft with allen wrench. Remember you must modify lower control arm to suit for clearance and or mounting.
Old 11-24-2017, 09:39 AM   #3
Tom Broome
Liked 88 Times in 43 Posts
I don't have any Cal Trac experience, but I second the recommendation to upgrade the front shocks. Afco's are a good choice, but they might still need some tuning.
Unless you have a deal on a specific brand like Afco. You might be better served by buying direct from one of the shock specialists with Stock and Super Stock experience. They can probably get you in the ballpark quicker.
Tom Broome is offline   Reply With Quote
Old 11-24-2017, 07:29 PM   #4
Nmbr1GMfan
Thanks, looks like Afco has some that even have factory mounting options.
Todd Greene
Old 11-24-2017, 08:30 PM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
What Hacksaw was saying is you will likely need to clearance the holes in the lower control arms...the body of the shocks are a bit fatter than factory units.
Rich Taylor
I/SA - 321
Old 11-24-2017, 11:03 PM   #6
Nmbr1GMfan
Thank you Rich.
Todd Greene
Old 11-25-2017, 10:11 AM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
The QA1 TD505 would be another one to consider for the front.
Supposedly, Calvert was working on an adjustable front but I haven't heard anything more on these.
"That'll never work....."
Old 11-25-2017, 11:42 AM   #8
Nmbr1GMfan
Seems reasonably priced and looks like they'll fit with no cutting so I could press on getting the lower arms painted without the shocks being here. And I just put a set of QA1 shocks on another car and I liked them.
Todd Greene
Old 11-25-2017, 02:40 PM   #9
HandOverFist
I'm using Calvert's 90/10 shocks on the front now in lieu of the Lakewoods...they work fine for now but time will tell if they last any longer.
I believe my front shock problem stems from the trailer miles rather than track use. Lots of jouncing on a trailer equates to heat and a shortened lifespan. I really need to stabilize the chassis when transporting...X2 if considering buying some of the upper end shocks for sure.
Rich Taylor
I/SA - 321
Old 11-25-2017, 03:55 PM   #10
Nmbr1GMfan
I have read people like the Calvert fronts better. Yes, trailer miles are tough on shocks for sure. I would buy the Santhuffs but I just don't know if we'll keep this car so I really don't want to cut the lower arm up so I can't reinstall the Lakewoods to resell the car. I know I will NEVER get my money back from high dollar parts.
Todd Greene
