Old 12-10-2017, 11:05 PM   #11
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Default Re: transmission shield required is stock
Originally Posted by GTS340 View Post
I asked Pat at NHRA the same question but didn't hear back. I would think so. I've tried the CSR on my old Super Stock car. Not user friendly at all. You end up cutting something to make it fit on a A-Body Mopar anyway. I've gone 440 B/SA in my Dart so I figure the CSR is worse with it. Scared to spend 500.00 to find out.
I also spent the money on the CSR carbon fiber complete flex plate,torque converter,transmission shield. I have a B body and can tell you that it does NOT fit into the tunnel even after cutting it up into [4] four pieces, waist of money.When I called CSR to discuss the issue NO help, just that they would not re-certify if modified/cut to fit. I explained this to Pat and he asked me to finish cutting/section shield to fit, epoxy it back together send it back to CSR and see if they could remold or modify to fit and to get back to him. Tough stuff to work with and I don't think they will work with me anyway. If NHRA does not allow us to modify the tunnel, mopar racers and possibly others are gonna have a tough time even with a blanket,at least you can crush them. The tunnel is reinforced with a structural member in the area of cross member/torsion bar collar. Pat also mentioned using a SFI case I'm not aware of one for 727.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 12-10-2017, 11:42 PM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I was able to use a CSR shield on by 67 Belvedere but had to do two things . To fit the shield to the trans , I had to cut quite a few bosses off the trans case . The shield fits like a glove , So I have it on the trans before I install it into the car . I have to let the engine tilt down in the back or I can't get at the top two bolts . I did trim back the flange where the trans tunnel to the firewall hangs down , then after the trans is bolted up to the engine , I jack it into place and install the trans crossmember . Its tight but it all fits . I wished that CSR would clearance the shield for the ProTrans band adjustment , and change where the buckle is for the strap , because its is wedged up in the trans tunnel , just move it down a few inches . Glad they are finally making the shields again , they were out of stock for almost a year .
Old 12-10-2017, 11:55 PM   #13
Liked 5,129 Times in 1,956 Posts
Wink Re: transmission shield required is stock
Wow, Hopefully Santa can bring me a blanket every 2 years along with my new seat belts......
Suggest going back to Junior Stock
Old 12-11-2017, 12:20 AM   #14
Frank Bialas
Is it possible that the 67 tunnel could be different/larger than the 70? I doubt it, but know that the manual transmission cars had a larger segment on drivers side to fit the shifter, also need to know if the new design CSR shield that you purchased had a large rib across the top towards tail shaft?
Old 12-11-2017, 12:29 AM   #15
Crew Chief
Liked 10 Times in 6 Posts
Originally Posted by Frank Bialas View Post
.If NHRA does not allow us to modify the tunnel, mopar racers and possibly others are gonna have a tough time even with a blanket,at least you can crush them.
Has anyone tried asking NHRA to allow the tunnel to be modified so a shield will fit?
Crew Chief is offline   Reply With Quote
Old 12-11-2017, 12:31 AM   #16
M Brand 505B
Liked 31 Times in 10 Posts
Removable tunnel would be nice.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 12-11-2017, 04:37 AM   #17
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
I asked the other day about just putting shield on inside of car "on top" of tunnel since your MAIN objective is protection for driver and didn't get an answer OR IS IT PROTECTION OF SURFACE from oil downs?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-11-2017, 07:03 AM   #18
ss3011
ss3011's Avatar
Yes it has that rib .
Old 12-11-2017, 08:25 AM   #19
Chris1529
Liked 70 Times in 29 Posts
Is this rule because there are so many transmission explosions in stock?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 12-11-2017, 11:32 AM   #20
GTS340
Liked 1,345 Times in 410 Posts
I haven't even burned up a clutch disc in my 45yrs in stock. We don't use transmission brakes. The way I see it Super/Street and E.T. racers are required.
Darn blankets get super dirty. Drag your straps throw the water box for a little extra cooling.
