Old 12-11-2017, 03:02 PM   #21
jmcarter
jmcarter's Avatar
Liked 3,250 Times in 989 Posts
Default Re: transmission shield required is stock
Anybody with experience using the Tom Waters shield on a 904? Want to avoid a repeat of a bad experience trying to mount a TCI shield in an A body years ago, lots of notching/trimming required which of course rendered the classification spec useless.
https://racecarpartsdepot.com/shop?o...roducts&page=2
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-11-2017, 03:06 PM   #22
Rory McNeil
Several years ago at Mission, Dan Cyrs A/SA 69 Camaro had an automatic transmission explosion so severe that it sent scrapnel up through the dashboard and out the windshield. Pretty scary stuff. Thay worked late into the night patching up the damage and installing a new windshield, and did race the next day. I have also seen the aftermath of several Torqueflights and Turbo 400s that blew apart, easily as bad as a clutch explosion on a stick car, but normally further back, and closer to the driver, and often in an area where the tunnel has been modified.
NHRA 6390 STK
M/S 85 Mustang
Old 12-11-2017, 06:02 PM   #23
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
I have the full carbon fiber CSR shield on the Volare. The transmission tunnel is tight, and it barely fits, but it fits. We use the star head pattern bolts (fir head?) that use a 3/8" 12-point socket, a good swivel, a 3' extension, and as SS3011 said, the trick is to let the engine and trans down as far as it will go to give yourself enough clearance to have a prayer of getting to the bolts. I remove the trans mount, pop the distributor cap off and lower the engine and trans down as far as they will go -- the engine lays back very close to the firewall. With the right tools and a lot of practice (which I have gotten over the years, unfortunately), it's not as much of a completely god-awful job as it used to be.
And yes, it required taking a couple of ears off the trans to make the shield fit.
Old 12-11-2017, 06:23 PM   #24
Liked 11,030 Times in 2,266 Posts
I think it is made of Kevlar.
Old 12-11-2017, 08:05 PM   #25
Michael Beard
They list it as an "aerospace composite". Whatever it is, it is TOUGH!
Old 12-12-2017, 04:17 PM   #26
340Cuda
Liked 805 Times in 341 Posts
I have a CSR shield in a 69 Barracuda on a 904. The shield fits the transmission very well after trimming the ears off.
It took a lot of work to get it to fit the car.
It is nice that they will re-certify them.
That being said the Tom Waters shield looks very nice.
Bill
Old 12-16-2017, 07:24 PM   #27
Jeff Teuton
Liked 325 Times in 50 Posts
I think I have a new-in-the-box-904-CSR. Somebody need it? Boy that is a long word.
Jeff Teuton 4022 STK
Old 12-17-2017, 05:07 AM   #28
Tom P
Liked 239 Times in 94 Posts
I was videotaping the car when that happened, of course my camera died later and I have never seen the tape except for playing it back on the little screen that day. I have no way to play Hi8 tapes or i'd make a You Tube video to scare you all into swapping to a stick!
It was just as the car came out of the burnout box and sent parts everywhere. Quite a bunch of damage to the car and maybe just luck the parts went straight up and straight down rather than out the sides , Dan can still walk.
Old 12-17-2017, 08:58 AM   #29
Crew Chief
Liked 10 Times in 6 Posts
What transmission was he using?
Crew Chief is offline   Reply With Quote
Old 12-18-2017, 03:03 PM   #30
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I have a Hi8 player if you want to send the tape to me.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
