Old 12-13-2017, 04:52 PM   #11
SS734
Liked 4 Times in 3 Posts
Default Re: Aftermarket/Replacement Cylinder Head Rule Change
Guys you are missing the point here.
Aftermarket heads are already accepted with a HP penalty. There is talk that they will become "replacement" heads and this result will eliminate the different factors of OEM vs. Aftermarket heads for the combos that currently have them.
Trying to find out "if" this does go through, what will happen to the two hp factors that are currently different?
SS734 is offline   Reply With Quote
Old 12-13-2017, 05:13 PM   #12
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Conceptually, when you place a different hp factor on an engine because of the use of replacement heads (aftermarket or OEM), you have essentially created a new engine for the books. The problem is the way that classification is calculated since it uses a weight break of one rating and then the weight of the new hp factor. Eliminating the differential of ratings will simplify the calculation for the guys in the field, which is always a good thing since it helps eliminate confusion and mistakes.
Old 12-13-2017, 08:30 PM   #13
CWhitney
CWhitney's Avatar
Liked 12 Times in 6 Posts
So does this mean that if a combination has been factored 20 HP now its gonna go back to the OG HP rating??
Example 396 Iron head is 375/385
396 Alum head is rated at 405HP
Both heads go back to 375?
CWhitney is offline   Reply With Quote
Old 12-13-2017, 09:49 PM   #14
james schaechter
Liked 1,436 Times in 299 Posts
It makes sense to me that there would not be a penalty in superstock. heads can be modified extensively. Stockers should keep the penalty for the aftermarket heads. My opinion anyway.
James Schaechter 3163 STK
Old 12-22-2017, 12:52 AM   #15
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
5hp off only for aftermarket head.....
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 12-22-2017, 08:21 AM   #16
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Boy, I didn't see that coming...aftermarket heads for SBC in Stock. With a 5hp penalty.
NHRA Tech Department makes updates/corrections to the Stock Car Classification Guide
Jan. 1, 2018
The NHRA Technical Department recently made changes to the Class Guide.
Buick 98-99 added missing pages to website
Chev 62-79 added SBC replacement heads for Stock
Chev 2015 Camaro 376 365 corrected shipping weight Stk/SS
Chev 1969 Corvette 350 300 separated auto/man transmission
Ford 2010 330 500 added Stock weight breaks
Ford 2012 330 510 added Stock weight breaks
Plym 1968 Barracuda 426 425/505 separated from non SS/AH
Paul Merolla is offline   Reply With Quote
Old 12-22-2017, 09:53 AM   #17
PJ305
Liked 5 Times in 4 Posts
Jan. 1, 2018
I looked up one of the Edelbrock heads for a SBC and it listed 185cc intake runner, the others were 172cc to 175cc intake runner. NHRA specs are 172cc intake and 65cc exhaust, how in the world can a stock racer use replacement heads that are so far out of whack from each other?
PJ305 is offline   Reply With Quote
Old 12-22-2017, 10:03 AM   #18
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Nice, and you guys think that there are NO crate motors in NHRA....
Originally Posted by Chris1529
Give everyone a stock replacement aluminum intake too and there you go.
You mean like the LD340?
Old 12-22-2017, 10:07 AM   #19
jmcarter
jmcarter's Avatar
Liked 3,198 Times in 977 Posts
Looks like Dwight is going to be busy!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-22-2017, 10:27 AM   #20
SDT1DYI
Liked 456 Times in 148 Posts
Does Edelbrock then make a SBC head with intake runners 161-165 CC's? Edelbrock is the only approved head? All I have seen is 180 CC and up.
Steve Teeter STK 6380.
SDT1DYI is online now   Reply With Quote
