Old 12-15-2017, 02:52 PM   #11
Coleydog
Liked 53 Times in 38 Posts
Default Re: Switch to 2bbl
Well you got me thinking, just checked on a 318 mopar in 70 & 69, 70 was 185, 69 - 172. Really, was there that much difference between the two? Hope someone who runs one can chime in.
Sorry if I jumped rails here.
Mike
The factor for the 70 is 15.32 and the 69 is 16.70. What class are these?
Mike
Old 12-15-2017, 03:44 PM   #12
David Lee
Liked 346 Times in 126 Posts
Originally Posted by Coleydog View Post
Well you got me thinking, just checked on a 318 mopar in 70 & 69, 70 was 185, 69 - 170. Really, was there that much difference between the two? Hope someone who runs one can chime in.
Mike
its funny the 318 in 68 is rated higher, even though its the same engine. I am going to asdk the powers that be to get the lower rating on the 68
Old 12-15-2017, 06:30 PM   #13
HR9121
HR9121's Avatar
Mike
Mike
70 would be O/S and the 69 would run P/S
James Williamson
W200 J/SA. SS/JA
Old 12-15-2017, 10:50 PM   #14
Coleydog
Thanks, but finally figured out where to find that.
Old 12-15-2017, 11:11 PM   #15
Mr Money, It really doesn't matter what the exact number is. Both will run way under.
They run J and K/SA with a 4 bbl ,and R and T with a 2bbl, and you're better off being in R and T.
Old 12-16-2017, 09:28 AM   #16
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
You're not using http://www.classracerinfo.com?? Shame on you!!
Old 12-16-2017, 10:54 AM   #17
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
If you were to get a proper 2bbl camshaft ground how much would it differ from a 4bbl grind? I’m under the assumption that you’d want less duration when you go from a 800cfm q jet to a 350cfm 2bbl. Thought hard about doing this with 350/255 before selling, I didn’t think there’d be much difference in the 69-71 350 going from 750 to 500 cfm but these later engines loose a lot more airflow capability
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-16-2017, 11:38 AM   #18
Coleydog
I've used it many times, just didn't look in the right place, now I know. Great info and very helpful.
Old 12-17-2017, 04:10 PM   #19
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
So am I looking at about .5 slower for my 1973 Nova 350/175/287 horse set up? .390/.410 lift cam, good 882 heads, Boburka 207 quadrajet, dish pistons, metric 200 trans with 5.13 rear. Car weighs 3470 in H/SA but would weigh 3418 in L/SA with a 2 barrel setup. I figured it at .90 better minus the .5 tenths loss on a carb swap so overall about .4 tenths better class for my combo? Does this sound right?
Old 12-17-2017, 04:13 PM   #20
rboyle
rboyle's Avatar
The index is .85 better and 50 lbs less so about .90 better but car slows up about .5 because of restrictive 2 bbl carb.
