Liked 20 Times in 9 Posts
http://www.nhraracer.com/content/gen...416&zoneid=132 So does this mean next year they will be checking for these big 55 and 60 mm cam journals.
7015 E/SA Sooner Storm |
#2 | |
Liked 800 Times in 237 Posts
Check out this older thread, specifically post #23:
http://classracer.com/classforum/sho...nal+cam&page=3
"That'll never work....." |
#4 | |
Liked 8,243 Times in 1,541 Posts
Liked 5 Times in 4 Posts
Liked 83 Times in 20 Posts
In 2010 Pat Cvengros wrote: The cam shaft may be of the larger journal design. Must use babbitt type cam bearings. Non-roller design.
Based on the above letter, you would think it would be permissible to run a big base circle cam. When considering all the changes to stock NHRA has made today with stocker heads, why would NHRA enforce a stock base circle cam. Pat Cvengros caused plenty of people to utilize the larger base circle cam which I believe would be very costly. A clarification needs to be made so racers know which way to go. The other question is how much could the big base circle cam help. It may not help at all!
John Duzac D/S 4448 STK |
Liked 8 Times in 5 Posts
#8 | |
Liked 1,952 Times in 439 Posts
Further, given the other absurd rules for Stock valvetrain, allowing those cam cores helped re-level the playing field that was thrown way out by the other rules. I'm not necessarily in favor of ANY of those rules, but if you're going to allow some to gain an advantage by opening some rules, you create an artificial advantage. And that's the problem with continually loosening the rules.
Alan Roehrich 212A G/S |
Liked 129 Times in 51 Posts
delete
Bobby Lundholm 3516 G/SA |
Liked 230 Times in 75 Posts
The reminder on NHRA for this rule also included larger diameter lifters, which i believe there are more of those then large journal camshafts. Either way there are a lot of blocks out there that would be not usable in stock anymore.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
