Liked 994 Times in 200 Posts
Is there any trick to putting a 60s cast iron intake on a 1986 305 engine that has the stock heads?Just picked up a 86 305 less intake.thanks and Hope Everyone has a Great New Year.
Liked 30 Times in 17 Posts
86 was right about the time GM started changing the angle on the center 4 bolt holes to clear the Throttle body on the TBI engines. If those four holes are 90 degree to the head then your old manifold will bolt right on. If the four center holes are tilted slightly you can "modify" the four center bolt holes in the intake to get the bolts to fit. Edelbrock makes some angle spacers to help but I have done a couple without using them and it worked fine.
Bill Koustenis |
Thanks for the info Bill.Yes this engine had a TPI induction system on it,but it was removed before I purchased it.I want to put a1965 afb intake on it,with a edelbrock afb style carb.So I can just elongate the center holes and it should work?
That should do it.
Bill Koustenis |
Liked 16 Times in 7 Posts
I thought they changed the center bolt holes around 1987? If you want one of the factory aluminum intakes (14101074), I have a nice one already cleaned up and ready to bolt on. It is for a quadrajet.
#6 | |
Either way the older intakes will work with just a little modifying of the center bolt holes. It sounded like Lyn wanted to keep the old school look.
Bill Koustenis |
1987 GM trucks had Throttle Body EFI, 1986 was the last year for carbs.
Ed Wright 4156 SS/JA |
