Old 12-14-2017, 12:51 PM   #11
Liked 5,137 Times in 1,960 Posts
Default Re: EX IHRA Stocker What does my car fit at NHRA
68 car is very limited in Stock ,without spending a boatload of money to keep up.
As a SS/GT car, it doesn't need to be full tilt to run under the index.
69 full size 327, 1.250 2 bbl, 235 / 207 hp rating. GT/QA.
9" radials, stall it up good on the footbrake...Good to go... Half second under, no heads up runs
You're welcome..
Old 12-14-2017, 01:17 PM   #12
Billy Nees
Now, that would work!
Billy Nees 1188 STK, SS
Old 01-11-2018, 03:21 PM   #13
Birch motor cars
Liked 3 Times in 1 Post
Cool Re: EX IHRA Stocker What does my car fit at NHRA
Thanks for all the replies, I have a lot to think about. Its just a pisser I have a complete (new) 350 330hp Legal engine sitting on the stand never fired, with no place to run it.
Birch motor cars is offline   Reply With Quote
Old 01-11-2018, 03:28 PM   #14
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Association combo races and NMCA will give you a chance you know...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-11-2018, 04:19 PM   #15
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
The pistons in that engine should be the same for the 71-80 dished piston 350's. Buy some of the glamorous new dart castings allowed,sell the vortecs to recoupe, use your valves etc in them, good to go for a smog era motor, cheapest you'll get! lol The '71 350 2bbl is likely a good combo, 233hp with OE heads or 243 with replacement, the "big" 2 bbl carb, you'd fit in around GT/OA and have an 11.45 Index, at 3200 pounds with factory heads, 3330 with aftermarket. Go for it!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 01-11-2018, 04:32 PM   #16
Billy Nees
71 350 doesn't get the big 2bbl.
Old 01-11-2018, 05:36 PM   #17
btrc
Liked 84 Times in 42 Posts
If you are from NW Iowa like it says under your name you can race it at most of the MCR combo races in your area. The only ones you can't I believe would be the ones that are also National Opens.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 01-13-2018, 10:01 AM   #18
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Would be a great 10.90 car and a lot cheaper to build/maintain. I see the Fletchers run the Nova in 10.90 lots, and then regular brackets etc. Just a thought.
The more people I meet the more I like my dog
Kevin
Old 01-19-2018, 05:45 PM   #19
Birch motor cars
I have been told I can race for at least the next two years with my Crate Motor with the Midwest Class Racers. I think that's what Im going to do and start collecting parts for a Legal NHRA combo.
Old 01-19-2018, 05:55 PM   #20
Birch motor cars
So, Chipper your saying I can use the motor I have and all I have to do is change the heads ? What intake and carb can I use ? Im assuming I can use the comp cam I have in the motor as well ?
