Liked 16 Times in 11 Posts
If you run Powerglide with pro tree brake (push button for reverse) you have 2 safety
it's safe, what the problem? |
Liked 348 Times in 152 Posts
Not quite sure what you're asking???
Phil Molski PMR Performance S/C 1623 |
It is dangerous to push in neutral after the win light? i have pro tree brake (button must be actived for reverse)
Liked 3,204 Times in 977 Posts
Don't be frustrated ghost; being from Quebec I'm guessing French is your first language...you might try running it through one of the translator apps...and no, not a danger clicking it into neutral.
Liked 239 Times in 114 Posts
If its a forward pattern VB its probably safe . A reverse pattern VB that by accident goes back into 1st gear instead of going from High gear to Neutral might be a problem. That is why there are a few VB's out there , that have a clean Neutral , so you never have to shift across a lower gear to get back to Neutral .
Merci beaucoup
Thankyou |
I thought it was bad to put a glide into neutral after crossing the line as it over spins the drum and can explode?
Liked 172 Times in 81 Posts
#9 | |
Liked 883 Times in 237 Posts
There is plenty of lubrication for the tailshaft ,especially since so many run the roller bearings.
