Liked 783 Times in 195 Posts
I think I have built my last 12 bolt, so I am clearing out the shelf.
Richmond 4.88 ring and pinion, used, good condition, few runs - $100 SOLD Richmond 5.13 Pro ring and pinion, used, less than 10 runs - $150 SOLD (1) Ratech pinion bearing spacer $10 SOLD Assorted bearings and seals $80, including: (1) Timken KD11786Y bearing w/races - GM and others 3/4T/1T axle bearing (1) Bower KD11786Y bearing w/races - GM and others 3/4T/1T axle bearing (1) NAPA Timken 387AS bearing w race - GM and others 3/4T/1T axle bearing (2) Timken LM501310 races - carrier bearing (2) Timken LM501349 bearings - carrier bearing (1) NAPA 1-1424 oil seal - pinion seal (1) Timken M802011 race - large pinion bearing (1) Timken M802048 bearing - large pinion bearing (1) Timken M88010 race - small pinion bearing (1) Timken M88048 bearing - small pinion bearing (1) Timken M88048 bearing w race - small pinion bearing SOLD (2) OEM covers, 1 w/OEM bolts, and (1) FelPro cover gasket, $20 for all SOLD Assorted yokes and U-Joints, $40 for all, including: (1) 1310 OEM u-bolt yoke, used (1) 1310 OEM strap bolt yoke, used (1) 1330 OEM u-bolt yoke, used (2) 1310 GM forged u-joints (1) 1330 Lakewood u-joint pn 23021 (1) 1330 Wesco pn 201-554 u-joint (1) 1310/1330 NAPA forged crossover u-joint Various u-bolts w/nuts. SOLDAssorted shims, $75 for all: New GM pinion shim packages: (1) 3893582 (2) 3893586 (1) 3893587 New GM carrier bearing shims: (1) 3851440 (2) 3851482 (1) 3851481 (1) 3876174 Collection of assorted thicknesses used pinion shims, approximately 30 count Collection of assorted thicknesses used carrier shims, approximately 50 count SOLD (1) 3867320 new GM Positraction spring plates, and (1) 3870899 new GM Positraction preload springs, $20 Plus shipping on all items.
![]() Last edited by Dwight Southerland; 01-21-2018 at 04:31 PM. |
Liked 8,209 Times in 1,536 Posts
Dwight, I sent you an e mail regarding the 5 13.....Thanks.....MJ. 502 49 nine. 014 zero.....
Liked 1,000 Times in 202 Posts
Dwight I would like to purchase the $40. package of yokes,u joints.Thanks
Liked 23 Times in 13 Posts
I will take the two 12 covers for $20.
Let me know shipping to 58265 North Dakota & pay pal info. Gary |
Liked 12 Times in 8 Posts
Dwight
I am interested in buying the assorted GM shims..$75 Please send me a text at 949-466-2272 Thanks! Duane Dickens NHRA7010 |
Liked 719 Times in 220 Posts
Dwight--
I would like the Ratech pinion bearing spacer for $10, plus all the bearings listed for $80. Email me at chevellegreg7376@hotmail.com with the shipping and total, and the address for me to send you a bank check. Thank you, also, thanks for your tech research and help! |
will take 4.88 if not sold
craig 330 831 4480 call anytime and we will make arrangements |
Greg -
Emailed you with total. Thanks!
