Old 01-09-2018, 11:41 AM   #51
ss chief
Liked 48 Times in 13 Posts
Default Re: Rochester 2GC info
Does anyone have contact info for Mike Town? Thanks in advance.
ss chief is offline   Reply With Quote
Old 01-11-2018, 06:43 PM   #52
G Anderson
Liked 4 Times in 3 Posts
Smile Re: Rochester 2GC info
You can find Mike on Facebook or PM me your Name and Phone# and I will forward to Mike
G Anderson is offline   Reply With Quote
Old 01-11-2018, 10:38 PM   #53
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Rochester 2GC info
This is a timely thread. I'm about to give the 350/230 a try in a car I built. I have a bunch of big 2 barrel cores, both venturi sizes, but the booster with the number is the kind of info I need. These are a pretty simple carb, there were a ton of 350's out there with them at one time, it should work. I had a 250 horse 348 when I was about 40 years younger,it was in an Impala with a 4 speed( broke more than a few third members with it, chucked a few 2 pc drive shafts, spent a lot of time fixing it again, but that was during the years this goofy state required you to install a retro NOX device to disable the vacuum advance, and it came with instructions on how to readjust the car's idle speed and mixture so as to attempt to reduce idle emissions, but all those devices did was reduce gas mileage and cause hard cold starts and stalling at idle. It seemed that factory multiple carbureted engines were exempt, so I got a complete 348 tri
power set up with intake,carbs,fuel lines,linkage and air cleaners for next to nothing and rebuilt the three carbs and installed it. I still had to disable the vacuum advance, but we had a Sun distributor machine in the place where I worked, that and a distributor curve kit with lighter springs and heavier weights made up for that. A co worker had a very nice 389 4 speed '64 GTO, we had to trim power that thing as well. The 64-65 had the large secondary carbs and the center one was a small 2GC,the '66 had three large 2 barrels. We got pretty good at making those things work,but that was a lot of years ago. This thread brings back some good memories,but that was then,this is now. Technology has improved a bunch as well. I'll be referring to this thread a lot in the coming weeks,maybe we can all compare ideas and get something done here.
Old 01-12-2018, 08:47 AM   #54
ss chief
PM sent to G Anderson
Old 01-17-2018, 06:15 PM   #55
Greg Reimer 7376
Question Re: Rochester 2GC info
Anybody have one or two of that good booster,#38864 you'd sell me? PM or email chevellegreg7376@hotmail.com.
Old 01-17-2018, 06:19 PM   #56
Larry Fulton
Larry Fulton's Avatar
We used to do that to the old 4GCs. We were told then that we could not remove & plug it. Many of us pulled the piston/spring, pushed the piston up, and put a ding in the rod with a pair of dykes so it could not extend again, and jetted up. Easy to find Rochester jets back then.
Easier solution is just leave the power piston in place, and plug off the power valve it's self... Take an Old Power Valve (or new), knock the pin & guts out of it... Turn it over and pound 3/16" lead shot into it... Now put the gasket back on it and reinstall into the bottom of the bowl... Jet to application.
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 01-17-2018, 09:22 PM   #57
Greg Reimer 7376
Seems to me, I soldered one shut on the tri-power setup.Heated it up on the stove,since its brass,it tinned up and soldered up real well.
Old 01-17-2018, 10:08 PM   #58
Mike Jones
Liked 684 Times in 289 Posts
Talking Re: Rochester 2GC info
Originally Posted by MikeMoller View Post
I'm no expert, but I found this interesting link for 2GC info - Hot Rod Magazine article
http://www.hotrod.com/how-to/engine/...g-carburetors/
Mike, I agree its interesting stuff, but the circle track 2GC`s are more modified than NHRA allows. Learn what you can and have fun.
Mike A114
