Old 02-24-2017, 01:07 PM   #31
Ed Wright
Ed Wright's Avatar
Default Re: What Works and What Doesn't
Originally Posted by Rsmith38 View Post
I have also used the Awesome orange from dollar Stores - works well.
They also have a refill bottle (clear plastic, yellow liquid) for $1 which makes 3 to 5 refills - for a couple of bucks you can do a trailer! Stuff also cleans under hood on used cars, Spray on - let sit, Hose off!
Good stuff!
Ed Wright 4156 SS/JA
Old 01-19-2018, 09:17 AM   #32
Liked 10,850 Times in 2,254 Posts
Working on the Drag Pack that has a S 60 Dana housing. Is it neat or what, it has screw adjusters to set the back lash and carrier bearing preload . No more spreading the case and adjusting the carrier with shim packs.
What doesn't work is calling the tech line and receiving incorrect information. I did some further looking on their web sight and found the correct procedure to set preload. I'm real happy I double checked, it saved me a bad day at the races, money for parts, and a lot of work.
Its a good product, I think.
Old 01-19-2018, 10:51 AM   #33
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
I'm all for clean and shiny cars ,but over the Winter a lot of racers forget about one of the most important things ,other than a win light , Brakes !
Take some time to inspect the hoses. ... if they are more than five years old replace them ,they are cheap insurance.
Flush out the old brake fluid and replace it with quality racing brake fluid like Wilwood's 570 Plus ,or other high quality DOT 4 fluid.
Brake fluid is hygroscopic ,it absorbs moisture and over time becomes corrosive to your steel and aluminum brake components .
We all want to keep the shiny side up !
Old 01-19-2018, 01:37 PM   #34
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
I always had issues with rear end seepage after a few months of racing . The bolts, even though they are self locking with Loctite always pounded out the gasket and leaked .. This gasket ends all that. It's a steel shim with reusable gasket material on both sides... and their cheap ..
Lube Locker Ford 9" Differential Gasket
https://www.amazon.com/Lube-Locker-F...ds=Lube+locker
Jeff Niceswanger 3740 SS
Old 01-19-2018, 04:59 PM   #35
Eman
Liked 133 Times in 76 Posts
Never wasted my time with a gasket on a 9". A tube of Ultra Black RTV and self locking nuts on the studs works for me. I used copper washers under the nuts.
Old 01-19-2018, 05:37 PM   #36
Jeff Niceswanger
I tried that Eman ..Pounded that sealer right out of there. Took a while to start leaking, but eventually,it would. I ended up using a Loctite red gasket maker, which set up like stone when the 2 parts were crushed together, but it's next to impossible to get apart without a chisel ! These gaskets don't leak, or crush
Old 01-22-2018, 03:42 PM   #37
Alan Nyhus
Liked 799 Times in 236 Posts
This stuff really works on differentials. -Al
https://www.permatex.com/products/ga...-gasket-maker/
"That'll never work....."
Old 01-23-2018, 08:45 PM   #38
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Wink Re: What Works and What Doesn't
This stuff has to be the best stuff on the planet. A little out of my price range .
http://www.chemicalguys.com/
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 01-23-2018, 10:34 PM   #39
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Adams polishes is even better!
http://adamspolishes.com
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 01-26-2018, 03:32 PM   #40
Don't work: Spools with .002 run-out on the pilot for ring gear, and .003 run-out on ring gear flange. Impossible for me to get .008 to .010 backlash and good contact area. A new one is on its way.
