#11 |
Liked 2 Times in 2 Posts
I use the good ol' Craftsman beam torque wrench. It's accurate and easy to use. Even Chrysler suggests the use of a beam type torque wrench.
Nautilus Racing |
#12 |
Liked 320 Times in 102 Posts
Years ago I used an S-K deflecting beam 1/2" torque with the pivot pin on the handle to keep the force in the exact position to get correct readings and today I still use a 50 year old 3/8" drive S-K beam torque wrench with a ball handle for setting up bearing pre-loads......
#13 |
Liked 204 Times in 54 Posts
Precision Instruments. I have several including the dial type which I use mostly.
http://torqwrench.com/ |
#14 |
Liked 4 Times in 4 Posts
[QUOTE=SSGT Mustang;554658]Precision Instruments. I have several including the dial type which I use mostly.
http://torqwrench.com/[/QUOTEwere nice looking product. I am going to call them tomorrow. thanks |
#15 |
CDI is one of the major torque wrench manufacturers and they make the torque wrenches for Snap-On.
http://www.cditorque.com/ Still, my preference for accuracy is my old Sears Craftsman Electronic Rotary Torque Meter that was discontinued many years ago. Had it checked many times for accuracy and right on spot. It measures ft/lbs, metric and torque angle. |
#16 |
Liked 885 Times in 238 Posts
Ron, SnapOn has a calibration service . Last I remember it was around $75 .
#17 | |
[QUOTE=ron b;554664]
https://www.thetoolwarehouse.net/Sea...on+instruments |
#18 |
Liked 126 Times in 20 Posts
Husky 27" 39104 available from Home Depot lifetime replacement. Haven't lost a cly head or ring gear yet.
Tim Worner SS 1747 |
#19 |
Liked 920 Times in 259 Posts
I have a variety of both the click style and "Torq-o-meter" dial type, all Snap On. I've tried to have enough of various click style wrenches so I only ever need to use the middle 50% of one to get a job done. They don't work well at the extremes of the range.
#20 |
Liked 129 Times in 53 Posts
A torque wrench only measures friction.If you do not follow the specs for the bolts you are using(lube,washers,etc.) you will be far off even with the most accurate wrench.
With that said I use SnapOn with dial for best result and "feel". Last edited by Race Clean; 02-02-2018 at 01:14 PM. |
