Old 02-06-2018, 05:02 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: NHRA fuel check
Originally Posted by GallopinGhost View Post
I have one of those on the Mustang...overpriced and a leaker to boot.
Rich Taylor
I/SA - 321
Old 02-06-2018, 08:22 PM   #12
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Will pump gas fail?
Old 02-06-2018, 09:01 PM   #13
J.R. Haddad
Liked 1,471 Times in 308 Posts
Is it on the approved list?
J.R. Haddad is offline   Reply With Quote
Old 02-06-2018, 09:23 PM   #14
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
approved ? wow, this shouldn't be rocket science.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 02-06-2018, 10:13 PM   #15
Ed Wright
Ed Wright's Avatar
The fuel has to be on the approved list. What's the big deal? They have to have a known good sample for comparison. They need to know the specific gravity, etc. Pump gas is all over the place. If you have not checked that stuff, it is easy to understand you not knowing that. Those tech people don't have it all that easy. I have done that at a local series. I try to work with them, and not give them any crap. Just follow the rules. They did not write them.
Ed Wright 4156 SS/JA
Old 02-06-2018, 10:30 PM   #16
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
Do not use the lever type of valve. I had one and bumped the lever working under the hood and had a bad fuel leak. Lucky it did not cause a fire. Now I use the push button type that cant stay in the open position. That was a lesson learned and a first round loss. I got mine from either Jegs or Summit.
Mike, a little Velcro strap goes a long way using the lever type valve safely....
Old 02-06-2018, 11:17 PM   #17
Kenney Kelley
Liked 72 Times in 36 Posts
Where would the approved Fuel list be found? I looked and didn't seem to find it. Thank You Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 02-07-2018, 08:41 AM   #18
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
http://www.classracerinfo.com/AFuelList.aspx
http://promod.nhra.com/userfiles/fil...edProducts.pdf
Look on Page 89.
Old 02-07-2018, 09:32 AM   #19
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Will pump gas fail?
Yes ! It has alcohol in it.
Old 02-07-2018, 10:51 AM   #20
Dan Fahey
Dan Fahey's Avatar
Is there an advantage which blend over another?
