Old 02-07-2018, 09:17 PM   #1
Rod Greene
Liked 242 Times in 81 Posts
Default Clutch Switch
What kind of setup are you stick guys using for a clutch switch to control 2 step? I never had a switch on the clutch just button on shifter. Pics would be nice.
Thanks, Rod
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-07-2018, 09:51 PM   #2
Don Fardie
Don Fardie's Avatar
Default Re: Clutch Switch
I use a Biondo switch working off the Z bar. It allows you to dial it in so it releases just where you want it to!
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
Old 02-08-2018, 09:25 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Don's setup looks pretty nice.
I may have to try that on my next clutch job !
I've used the Jerry Bickel switch in the past which is a very heavy duty switch with molded in leads and an adjustable arm .
they also have a universal mounting bracket for it.
Old 02-08-2018, 09:41 AM   #4
terry1
Liked 24 Times in 13 Posts
Smile Re: Clutch Switch
What is the issue with a switch on the shifter in Stock.
I believe the SS people are allowed one on their shifter.
Terry K
terry1 is offline   Reply With Quote
Old 02-08-2018, 09:59 AM   #5
Denny Steward
Denny Steward's Avatar
Liked 131 Times in 24 Posts
Rod, you have a PM
Denny Steward GT/JA 246
Denny Steward is offline   Reply With Quote
Old 02-08-2018, 11:03 AM   #6
Ed Wright
Ed Wright's Avatar
Some Stockers have a switch on the brake pedal for their 2step.
Ed Wright 4156 SS/JA
Old 02-08-2018, 08:51 PM   #7
Rod Greene
[QUOTE=Ed Wright;555487]Some Stockers have a switch on the brake pedal for their 2step.[/QUO
That would be quite feat. 3 pedals at once.
Old 02-08-2018, 09:02 PM   #8
Mark Ugrich
Liked 71 Times in 38 Posts
When I did mine , I drilled and tapped the end of the clutch pedal shaft. Then bolted a throttle lever from an old Rochester two barrel to it . Made a 90* bracket and attached it to the pedal support and used a standard GM brake light switch.
Old 02-08-2018, 09:02 PM   #9
Rod Greene
Terry K
Unless the rules have changed again. I believe the stockers have to have 2 step controlled by clutch. It is a stupid rule that just adds extra wiring and points of failure.
Thanks for the replies guys. I am exploring options on the set up. I assume that both those switches have to be adjusted every time the clutch is adjusted correct? Is one more user friendly than the other? I have figured out how to use 2 relays to lock the line lock and 2 step together just working on clutch switch configuration and location for ease of use.
Old 02-08-2018, 09:19 PM   #10
Rod Greene
I went on the BIONDO web site couldn't find the switch. Do you have a part number?
Thanks, Rod
