Old 03-04-2018, 07:48 PM   #11
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Sfi 200 metric case
Originally Posted by Todd Hoven View Post
The point of the SFI case is not only because it’s stronger, it is so you don’t have to purchase a blanket or shield. A different production case doesn’t solve this issue.
Correct, however, there has been an issue with cases cracking and the reason why they sell braces to prevent the cracking.
Old 03-04-2018, 10:49 PM   #12
While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.
Joe, Did they make a 3 speed diesel case?
Old 03-05-2018, 10:34 AM   #13
SSDiv6
Yes they did. GM cars, including Cadillac that were powered with the Olds 260 and 350 Diesel engines, depending on the year, had either the THM-200, THM-200C or THM-200-4R transmission. All the cases were BOP and beefier.
However, the first year the engine was introduced, 1978, the transmission was a T-250.
I learned about it from a former colleague of mine, that was a drivetrain/transmission engineer at GM. On the side, he rebuilt transmissions at home. He heard me talking on the phone with another racer about the T-200 trans and he asked me if I needed a stock transmission. Also gave me a dissertation of all the GM transmissions and told me he had a BOP T-200C and he rebuilt and didn't have a use for it.
He shared the transmission had a beefier case for the diesel application. When I picked it up, he was not kidding. The bellhousing and case were beefier and did not look like the case of a T-200 I had purchased from TurboAction.
Old 03-05-2018, 10:57 AM   #14
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Thumbs up Re: Sfi 200 metric case
ON A SIDE NOTE:
The 350 case from ATI looks like it is a Chevrolet pattern only?
That is just dumb.
Besides that, the TH 350 in drag racing is not all that popular any more, in cars that would need an SFI case.because of the new rule.
As well,
IF,...AND THAT IS A BIG IF!!!
Someone was to make a TH 200 Metric SFI case.
In my opinion the corporation should consult with the likes of Scott McClay, and Leo Glasbrenner.
In an attempt to have things set up in the case so they will work with no modifications.
And a dual pattern bell housing to fit Chevrolet and B.O.P. would also be a necessity.
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 03-05-2018, 11:06 AM   #15
GUMP
Liked 2,355 Times in 554 Posts
Originally Posted by MEXJOE View Post
ON A SIDE NOTE:
That is just dumb.
ATI says that you can use any of their bell housings......
Old 03-05-2018, 12:08 PM   #16
ON A SIDE NOTE:
That is just dumb.
As well,
Glen,
It's still would have to be mucho expensive, the way I see it. It's still just a tiny niche market.
