Liked 184 Times in 113 Posts
What are some of the benefits adding a cool can to the fuel line?
Where are the best places to locate them? d |
Doubt you will see any with an EFI car. Was more of an issue in the old days on vehicles with carburetors.
Ed Wright 4156 SS/JA |
Liked 19 Times in 12 Posts
Pretty sure they utilize aluminum fuel lines which is a no-no with EFI.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Liked 2 Times in 2 Posts
Not sure about this, but didn't the rules in stock yrs ago require a stock style mechanical fuel pump on the block? I'm sure fuel coming out of that thing would be a lot hotter than fuel coming from an electric pump in the trunk.
Liked 2,487 Times in 698 Posts
Not any more!
Banned
Liked 179 Times in 89 Posts
Isn't there a new rule that a cool can must be empty of coolant before leaving the staging lanes?
You can make one with any kind of tubing you need. Fuel doesn't sit in the lines under the hood, and have to pass through a hot mechanical fuel pump, like we used to have to use in Stock, absorbing heat from the engine it is bolted to.
EFI constantly pumps fuel back to the tank or fuel cel, never go through anything hot bolted to the engine block, circulating it through the cooler tank/cel. Does not get as hot as in "the old days". I have not seen a cool can in years. No need on an EFI car anyway.
Liked 22 Times in 22 Posts
I always ran, and am building a 67 deuce, and will always run a cool can. Ours may be a little different. We found a place in Japan that custom built them. They were well built aluminum, with a large 1/2" tight coil that either a 16 oz. or 24 oz. empty beer can is filled with water, frozen solid, then slipped perfectly into the middle of it with -8 fittings in and out. Then you fill the rest with water, and it has a rubber insulated and o ring sealed screw on cap. Did back to backs when I owned a local track, and we decided there was .01 to .02 difference in et's to the benefit.
don,t have one |
#10 | |
Liked 586 Times in 162 Posts
