Old 03-12-2018, 12:32 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Stocker Roll Bar
Live in Montgomery County, MD - Rockville/Germantown
Need a NHRA Certified Roll Bar Installed !
Who and where can I get this done?
Dan
Old 03-12-2018, 01:09 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Stocker Roll Bar
You want one of the best? Ken Keir Race Cars.
Hacksaw is online now   Reply With Quote
Old 03-12-2018, 03:08 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Is there such thing as a NHRA certified roll bar?
S/ST 51
S/C 53
Old 03-12-2018, 03:26 PM   #4
Hacksaw
You are correct, there is no " certification " , but there are min. requirements, ie: 1.75" tubing with a min. of .118 on the wall on mild steel as well as proper mounting methods.
Old 03-12-2018, 04:34 PM   #5
Dan Fahey
Dan Fahey's Avatar
Thanks for the information...
Does it make any difference to buy one pre-made or have it custom fitted?
Dan
Old 03-12-2018, 05:17 PM   #6
Lee Valentine
Liked 319 Times in 68 Posts
Dan, I've used pre made kits from S&W and had good luck. Make sure the bar is installed as per the rule book.
Lee Valentine 1661 STK
Old 03-12-2018, 06:37 PM   #7
Hacksaw
Dan
Most kits on the market are .134" tubing to make sure it meets the min. of .118". A quality shop will use .120" or .125" and check the thickness to make sure it will pass. They may have to buy DOM tube, more money, better product.
Old 03-13-2018, 11:24 AM   #8
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
^^ I agree.
Both of my Stockers have S&W kits.
Very pleased with their quality and customer service.
One thing I did find out after installing the kit in my 2009 Stocker :
If I had special ordered a "relaxed fit" main hoop cross bar with a 2-3 inch set back ( instead of the normal straight piece) then my seats could
have reclined further back. I did not know this until after I installed the kit.
Being a novice at roll bar installations, I can now see why chassis shops charge so much. To fit things right it takes a lot of time
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-13-2018, 02:29 PM   #9
Dan Fahey
Dan Fahey's Avatar
Originally Posted by ALMACK View Post
^^ I agree.
This good information !!
Would like a Roll Bar setup where you can get out of the Seat easily without being Gumby !
Also be able to sit in the back seat.
Thanks
Dan
Old 03-14-2018, 11:51 AM   #10
ALMACK
ALMACK's Avatar
Thanks
Dan
Dan:
here are the pics of the 09 Mustang.
Because the seat back did not lean back to it's normal position, I had to "flip" the head rests...otherwise with a helmet on there's no way I'd be comfortable. I may still cut the cross bar out and install a 2" setback version
Also, I think it may be tough to make it easy to sit in the back seat by following the current rules regarding roll bars. I tried to crawl under mine. Going over would be easier if I needed to.
I do like the fact that I can remove any of my seats easily
I/PS '95 Mustang GT
