Old 03-20-2018, 09:58 AM   #11
FED 387
Liked 333 Times in 180 Posts
Default Re: Mounting MSD
maybe mount it on a panel with Dzus fasteners so that it is easy removal---also when you bolt the MSD to the plate perhaps use rubber insulators to isolate vibrations from the unit---FED 387
Old 03-20-2018, 10:15 AM   #12
BTR69
BTR69's Avatar
Liked 85 Times in 26 Posts
This ones the 6AL that comes with the rubber insulators. Not sure what else I can do or use to help dampen any vibration with it yet, but i'm open to suggestions. I do have some 1/4-1/2 inch rubber patches, roughly 10-12 inches long laying around somewhere I may try to incorporate as well.
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 03-20-2018, 11:26 AM   #13
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
These units have indicator lights to let you know if they are firing correctly. I like having mine (version 8) in sight from the drivers seat and accessible for changing the rpm settings either by chips or dials. My distributor advance is locked out. I have one of the MSD Starter Saver boxes mounted to the backside of my glove box door. I can drop the door and see what it's up too, also.
But then I'm a hard core tinkerer...
Dale Shearon
68 Mustang 6394
