Old 03-27-2018, 11:27 AM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Stocker Cam
Originally Posted by FrankM View Post
Hey Dan,
I talked to Charlie at ATI for my 8" non lockup for my 4l60e and Ed Wright removed the lockup from the PCM. Also, Ed said to use a 96+ PCM because a 95 won't allow a stall above 2200ish. I haven't run the car yet so can't comment on how it will run.
I have ODB 1 using work-a-round fix, did that 10 years ago.
Using a Yank 4400PT lock up now..
The lock up make the car cruise at a decent rpm driving it on the street.
D
Old 03-27-2018, 02:00 PM   #12
Dan Fahey
Dan Fahey's Avatar
Stocker Cam and Brakes!!
Does anyone have a problem using power brakes with a large duration cam?
D
Old 03-27-2018, 02:15 PM   #13
Irace007
Liked 17 Times in 12 Posts
Lack of vacuum will be the problem.Canister or Hydro Boost (P/S) set up will fix it
Good luck
Marty Hanft
Irace007 is offline   Reply With Quote
Old 03-27-2018, 03:46 PM   #14
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Most aftermarket controllers don't need a MAF . It might be a restriction on the inlet . If you don't use 4th gear , then why not lock up the converter in 3rd gear and get that benefit in efficiency ?
Old 03-27-2018, 05:18 PM   #15
Dan Fahey
Dan Fahey's Avatar
Good luck
This is new to me.
How are they hooked up?
D
Old 03-27-2018, 05:51 PM   #16
GUMP
Liked 2,361 Times in 558 Posts
That was my line of thought. I would at least try it if I had it......
