Old 03-28-2018, 07:25 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: Package tray
this is an older thread I started, do we have to have the package tray area upholstered or can it just be painted?
Old 03-28-2018, 07:39 PM   #12
FED 387
Liked 334 Times in 181 Posts
just remember that aluminum is about 1/3 the weight of steel --- so if you install a 1/2 inch thick steel gas tank shield between the OEM gas tank and the trunk floor you should be ok and exceed the NHRA guidelines for the thickness suggested. Make sure you have really good straps supporting that tank (lol)
Old 03-28-2018, 07:42 PM   #13
6130
Liked 117 Times in 50 Posts
Originally Posted by Painter View Post
I have found that one inch boiler plate works real well for covering the packsge tray and rear seat areas. A little difficult to get into position but i feel that it gives an extra margin of safety between the driver and fuel cell.
Lol.
Old 03-28-2018, 08:46 PM   #14
David Lee
LOL
I jave all the wholes covered with the proper thickness, can i paint it or do i have have to have some material covering it
Old 03-28-2018, 09:31 PM   #15
Liked 5,141 Times in 1,963 Posts
Originally Posted by David Lee View Post
LOL
Get some matching latex and then empty out your vacuum cleaner bag into it. If you do it right, it will look like tweed.
Old 03-29-2018, 08:17 AM   #16
Liked 10,852 Times in 2,254 Posts
Do whatever it takes to keep the fire off of you!
Old 03-29-2018, 08:29 AM   #17
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Reminds me of the story I read on CR a long time ago about a racer hiding iron Hemi heads in the back seat cushion! Art Leong, maybe?
Paul Merolla is offline   Reply With Quote
Old 03-29-2018, 10:35 AM   #18
Timetraveler
Liked 12 Times in 6 Posts
If we use a fuel cell and install a fire wall we should be able to leave the seat out even without a roll bar installed.
Timetraveler is offline   Reply With Quote
