#11 |
Liked 346 Times in 126 Posts
this is an older thread I started, do we have to have the package tray area upholstered or can it just be painted?
#12 |
Liked 333 Times in 180 Posts
just remember that aluminum is about 1/3 the weight of steel --- so if you install a 1/2 inch thick steel gas tank shield between the OEM gas tank and the trunk floor you should be ok and exceed the NHRA guidelines for the thickness suggested. Make sure you have really good straps supporting that tank (lol)
#13 |
Liked 117 Times in 50 Posts
#14 | |
I jave all the wholes covered with the proper thickness, can i paint it or do i have have to have some material covering it |
#15 |
Liked 5,134 Times in 1,958 Posts
Get some matching latex and then empty out your vacuum cleaner bag into it. If you do it right, it will look like tweed.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 03-29-2018 at 11:17 AM. |
#16 |
Liked 10,838 Times in 2,253 Posts
Do whatever it takes to keep the fire off of you!
#17 | |
Liked 293 Times in 65 Posts
#18 |
Liked 12 Times in 6 Posts
If we use a fuel cell and install a fire wall we should be able to leave the seat out even without a roll bar installed.
