With a 398 ci motor what would the weight be base off of for that ci and index ( class ) for modified super stock in a fwd conversion car ?
SS/AM-7.50 lbs per ci Index-9.00
SS/BM-8.50 lbs per ci Index-9.20 AM-2,985lbs 2,836lbs with an automatic transmission BM-3,383lbs 3,214lbs with an automatic transmission
Christopher Dodd 4615 GT/EA |
Liked 314 Times in 177 Posts
SS/AS 3380 lbs @ 9.60 index. SS/AM 2985 lbs @ 9.00 index , minus 5% if you use auto trans, either class.
Thanks guys
Forced to put scoop on car with combo |
Liked 805 Times in 341 Posts
R5Rob:
Looking at your screen name is this going to be an R5P7 engine? Thanks, Bill |
Sold all my R5 stuff
Gen 3 Hemi going in my avenger |
Liked 5 Times in 2 Posts
Sounds like an awesome build. Are you using one of the new aluminum G3 blocks? and what rocker arm system did you end up going with?
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
Liked 237 Times in 126 Posts
In Modified Stock section 12D (one four barrel) a Hemi can only run in AS.
In Modified section 12F (two four barrel) a Hemi can run in AM or BM. There are cylinder head restrictions for each each class, read the rule book with care.
AS single carb is limited to cfm
Plan on to run AM with no restrictions on carb or dual carbs allowed Mine is setup with single billet 2.400 Last edited by R5ROB; 04-04-2018 at 06:49 PM. |
No on the billet carb. But ... check out Scott Gove's Avenger, SS/AM 7.90's car really rocks!
