Old 04-20-2018, 11:33 AM   #71
House of Darts
Liked 20 Times in 15 Posts
Default Re: Hooray!
I hope this post started with a 55 gallon drum since everyone is taking a piss in it. There are several posts from Dan Fahey about Pure Stock. Lots of pissing and moaning about the class entering NHRA.. And boy, these comments seems to be calling for that class.
House of Darts is offline   Reply With Quote
Old 04-20-2018, 02:01 PM   #72
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: Hooray!
jim mantle .... turbo glide has two planetaries and a direct drive .... how could it not be 3 speed .... low gearset was billed as GRADE RETARD for going downhill , hence the GR on the shift plate...
also had the twin convertor ....
my dad said its downfall was pumps inability to maintain enough pressure to keep slippage down so they were junk after 30-40,000 miles
captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 04-20-2018, 07:11 PM   #73
Barry Polley
Guest
Posts: n/a
Default Re: Hooray!
second link....
http://srmncrauto.blogspot.com/2015/...nsmission.html
Old 04-21-2018, 07:42 AM   #74
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Hooray!
Stock became Super Stock without the unlimited high lift cam!
Todays Stocker run quicker and faster than yesterday’s Super Stockers with less lift!
Old 04-21-2018, 08:40 AM   #75
James Perrone
Liked 1,840 Times in 428 Posts
Default Re: Hooray!
Delusional Dan
james perrone 1290 STK
Old 04-21-2018, 09:02 AM   #76
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: Hooray!
Originally Posted by GTS340 View Post
Hooray for some I guess. Might as well spread the joy. Original transmissions, original rearends, Roller rockers, Bee hive springs, 375/396 pistons. I'm sure the list could grow like wild fire.
I'm alright with the intake and it actual effected me personally. But try and remember that money was wasted here. As my Dad always told me. "If you have nothing good to say. Keep it to yourself."
Paul Haszlauer
?/SA 7019
Paul… 375/396 Pistons? Please tell me more. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 04-21-2018, 01:22 PM   #77
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Hooray!
Opening a can of worms...
With the current camshafts in used, there is no way the valves will clear the piston dome. Many years ago, in the 1900's, a racer asked me to stop by his home to check why his new Crane Cams Stocker cam would not clear his pistons.
He believed he was doing something wrong. After checking the cam, the cam was not the problem; it was the piston domes. After making a few phone calls, I learned many were having their pistons flycut to be able to run the cams.
Having compared the current approved pistons versus the original, and they are very different. I assume someone may have sent a modified piston to NHRA to get approval of the alternate approved pistons.
ID:	44662   Click image for larger version
Old 04-21-2018, 04:32 PM   #78
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Re: Hooray!
Huh, that's weird, because a friend of mine used to run the approved TRW L2242F30 pistons with a Lunati stocker cam and no issues. This would have been back in the early to mid 1980's. They had unmodified top domes and his heads were the #840 castings IIRC.
Old 04-21-2018, 06:30 PM   #79
SSDiv6
Default Re: Hooray!
In the mid 1980's they still checked duration and overlap. After changing the rules allowing any duration and overlap, everything changed. The lobes, duration and overlap changed.
Old 04-21-2018, 06:58 PM   #80
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs up Re: Hooray!
Yepper.......That's how it happened !
