Old 05-17-2018, 02:44 PM   #31
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Front tire pressure adjustments
Originally Posted by tony wood View Post
ok this is gonna sound stupid but try ankle weights used them on my stick super stocker was going 10-15 red try 5pd weight
I think that would be taken as loose ballast (illegal).You would need a MD's cert.calling it some form of prosthetic...lol
Old 05-18-2018, 04:55 PM   #32
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
damn! never thought of that!
I gotta try it
Old 05-18-2018, 05:00 PM   #33
Tom keedle
Tom keedle's Avatar
would it be any different if it was 5lbs of lead in a shoe?
Old 05-18-2018, 06:03 PM   #34
Jim Caughlin
Liked 805 Times in 245 Posts
I would think there is grounds to consider that the whole front tire pressure affecting RT's might be somewhat of an urban legend. As a test, I put my car on a flat floor in the shop and put a 3" block in front and behind the front tire at the 40PSI that I normally run and measured the distance between the blocks. I then started lowering the pressure in increments and remeasured the distance. I got all the way down to 15 PSI (which I thought was probably an unsafe pressure to actually race at) and the distance between the block had barely changed. Maybe the 3" height wasn't quite right but it has to be pretty close to the correct height for the photocell. Based on that, I kind of wonder if the real life change in RT is in the drivers head and not a result of the rollout. If you doubt my test, try it yourself.
Jim Caughlin
SS6019
Jim Caughlin is offline   Reply With Quote
Old 05-18-2018, 06:08 PM   #35
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Someone has a detailed mathematical analysis of this online that reached the same conclusion. I think you need to focus on other parameters rather than tire pressure.
Dave Muller is offline   Reply With Quote
Old 05-18-2018, 09:42 PM   #36
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
A brake pressure switch will work for some, not for others. When I tried one on my Skyhawk, I found out I don't pull my foot up consistently off the brake pedal. Way too much variable with reaction times, went back to button in pedal. Was between .008 and .036 in six runs today testing.
Lane Weber
Old 05-18-2018, 11:03 PM   #37
superstock45
Trust me from 40-17 works. It's worth about .012-.015
superstock45 is offline   Reply With Quote
Old 05-19-2018, 09:10 AM   #38
FED 387
Liked 334 Times in 181 Posts
yep -- it does work ---not sure how much on everyone's car but on 3 specific cars I have seen it will slow down the reaction time--- not going to give you any numbers but it did change the RT
Old 05-19-2018, 10:15 AM   #39
Ed Wright
Ed Wright's Avatar
I would make sure that 17 psi tire was on the inside at the turn off.
Ed Wright 4156 SS/JA
Old 05-19-2018, 10:32 AM   #40
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Was told to do this many many years ago by Tony Cowell.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
