#41 | |
Liked 806 Times in 246 Posts
Jim Caughlin SS/ES 6019 |
#42 | |||
Liked 117 Times in 50 Posts
#43 | |
Liked 373 Times in 131 Posts
1996 and newer with a 15 % reduction would be nice. Doesn't seem like it will happen now so all the '96-'07 combos are stuck with what they are I suppose. Just a hand full of the 1996-2007 production cars are running in Stock now so there are all those combos in the guide that will never be tried. Too bad because there are so many really nice condition OBD II cars out there cheap
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#44 | |
3" o/r downpipe, tune, and NHRA spec fuel on the approved list. You should be able to run index easy. You will need a fuel sampling valve in the car's fuel system and submit samples after a qualifying run. The roll bar and driveshaft loop are easy adds. The tune is the key with that 2.3EB. Those cars are soooo under rated and de-tuned from the factory because Ford has to deal with the habits of the driving public and also for warranty reasons. If they released the cars with a better tune they would risk someone putting lousy 87 octane fuel in it and detonating the engine under warranty so there are safeguards built into the factory tune. If that combo ever gets factored to G then it will need an SFI harmonic balancer
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 06-14-2018 at 07:19 PM. |
#45 | |||||
But then again, he's running several tenths under the B/SA index in a street-driven car with air-conditioning. ![]() Quote:
#46 |
I think you will find that this engine does not have a damper of any kind on it.
#47 |
Liked 7 Times in 5 Posts
I believe that it has a balancer on it. The picture on the Ford Performance website looks like a balancer.
https://performanceparts.ford.com/part/M-6007-23T Roland |
#48 |
I know the old 2.3 Turbo Ford ( Pinto based engine) does not use a damper. Not sure about the EB
#49 | |
I believe the 2.3EB uses direct injection at super high PSI numbers. Might have to locate the sample valve in line between the tank and where it feeds into the high pressure direct injection pump. It's not simple like the older efi cars
#50 | |
