#151 | |
Liked 117 Times in 50 Posts
Ford lists the power peak at 6,500 rpm and the torque peak at 4,250 rpm, so it would need a pretty loose converter and some gearing. The Stock Classification tool lists the throttle body as being 2.913" (74mm). And first gear in the 6R60 transmission is 4.171. |
#152 |
Liked 983 Times in 314 Posts
Anyone look at NHRA engine blueprint specs ? Max compression 15.52 to 1. Are there any errors in those specs?
#153 |
Liked 808 Times in 247 Posts
I wish someone could tell me how to do that! I'm building a NA version of this motor and there isn't enough dome and head milling to get that under any condition.
#154 | |
Liked 88 Times in 43 Posts
If you follow the Specs and do the math, it comes up at 13.98. Not sure where the max compression of 15.52 comes from. I'm with you, I don't expect you will get 15:1 with around stock bore and stroke. To get there would require a TDC volume of around 40cc. Tough to do with a deck clearance that seems more workable than the Spec of .023. |
#155 |
Are you guys building 2.3 engines for Stock Eliminator?
#156 |
So is this a dished or domed piston?
#157 |
No, this is a motor for SS/Modified. Pretty much all of the dome and smallest combustion chamber and still getting enough valve relief gets you in the 15:1 range. I currently run the 2.3 Ford single cam engine but am in the process of building a Duratec motor which is an Ecoboost without the turbo.
Jim Caughlin 6019 SS/ES |
#158 | |
#159 |
Liked 129 Times in 51 Posts
We just got a 2018 Ecoboost 6 speed in today at work. K/S?
Bobby Lundholm 3516 G/SA |
#160 |
Liked 184 Times in 113 Posts
AND this Mustang is one of the whole new generation of Stockers.
More to come.. D |
