Old 06-26-2018, 01:31 PM   #11
nhramnl
Liked 358 Times in 83 Posts
Default Re: Valve Spring Pressure - BBC stocker
Originally Posted by Tom Broome View Post
Hard to loft an intake valve on opening, it's only moved the tappet .100 or so. Now over the nose....okay, but the piston is long gone by that time. Possibly a big bounce off seat? Pushrods might change things
Not disagreeing with what you're saying, but if the opening ramp of the intake lobe is too close to "instantly vertical" (like what roller cam guys are using these days) the lifter can actually try to dig into the lobe and create milliseconds of valve train slack (shudder), which can cause things like valve spring surge. Even the roller cam guys admit that there is only so far you can go with "snapping" the valve open and closed.
Old 06-26-2018, 03:06 PM   #12
ghost
Liked 16 Times in 11 Posts
Do you run with Hydrolic lifter????
How many lash you have between rochers to valves 0 or 1/4 lap
ghost is offline   Reply With Quote
Old 06-26-2018, 05:44 PM   #13
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Spoke to COMP today, they are claiming that the lobe is so aggressive I need to get a different spring that is going to allow me the same open pressure, but within .050” of coil bind. He claimed that the spring is most likely doing the hokey pokey since it’s about .400” from coil bind, and not designed to work there. I thought pressure was pressure, but is this something that could actually be going on and therefore causing such an issue?
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-26-2018, 05:59 PM   #14
Rob Wright
Liked 21 Times in 7 Posts
Possibly a big bounce off seat? .
Probably. Horribly upset combinations can/do bounce that much. Sometimes it gets better with less spring pressure. Maybe not with this one, but it's not unusual.
Rob Wright is offline   Reply With Quote
Old 06-26-2018, 06:32 PM   #15
Hacksaw
Liked 312 Times in 175 Posts
I think the info from Comp is accurate, but I think looking for another cam and matching springs is in order.
Old 06-26-2018, 07:10 PM   #16
Liked 1,880 Times in 422 Posts
What valves and pushrods are you using?
Old 06-26-2018, 07:12 PM   #17
Chipper Chapman
Ferrea Competition valves (not the hollow ones as I was told they are illegal) and trend 3/8x.120 wall pushrods
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-26-2018, 08:20 PM   #18
Tom Broome
Liked 88 Times in 43 Posts
You answered your own question. You can't open a flat tappet with a specific diameter to the point that the lobe runs off the lifter face radius. That number is somewhat flexible depending on lifter face diameter (remember mushroom lifters?) and base circle diameter.
How far open is the valve at the point of minimal valve clearance? Is it really going to "surge" at that point in the cycle? Could it be a bounce induced from the closing cycle?
Tom Broome is offline   Reply With Quote
Old 06-26-2018, 08:23 PM   #19
Tom Broome
Pushrods are a spring also. The rate gets altered through diameter and wall thickness.
Old 06-26-2018, 08:33 PM   #20
Tom Broome
They own a Spintron, not me, but inducing spring clash is possibly a solution, probably not the most elegant....but a solution.
