Old 07-04-2018, 12:21 PM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Online source for electrical connectors
Getting ready to wire my car and need a good online source for elect. connectors, etc. thanks
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 07-04-2018, 01:28 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Default Re: Online source for electrical connectors
waytekwire.com
CMcAllister is online now   Reply With Quote
Old 07-04-2018, 01:42 PM   #3
Painter
Liked 162 Times in 45 Posts
Wherever you get your wire and connectors look at getting marine grade. The wire will have a higher strand count which makes it more flexible and will be tinned copper which prevents corrosion. And the terminals will be tinned to prevent corrosion.
Painter is offline   Reply With Quote
Old 07-04-2018, 02:08 PM   #4
Matt S
Liked 20 Times in 12 Posts
Couple more places to look also:
www.terminalsupplyco.com
www.delcity.net
www.wirebarn.com
Matt S is offline   Reply With Quote
Old 07-04-2018, 02:40 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
X2 on DelCity! Huge inventory and very fair prices!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-04-2018, 05:42 PM   #6
GallopinGhost
Thanks guys, that should do it.
First off I need some kind of connector for the starter so I can put 12" or so leads on it before it goes on the engine
Brian Carpenter
Stock 1358
Old 07-04-2018, 06:37 PM   #7
Ed Wright
Ed Wright's Avatar
Brian, are you talking about a connector & terminals for the wire to the small stud on the starter solenoid?
Ed Wright 4156 SS/JA
Old 07-04-2018, 07:18 PM   #8
GallopinGhost
Ed, I'm looking for something like this that can stand the heat from the headers, maybe it's good enough.
https://www.cabelas.com/product/Wire...E&gclsrc=aw.ds
Brian Carpenter
Stock 1358
Old 07-04-2018, 07:39 PM   #9
Ed Wright
Ed Wright's Avatar
Brian, the way I have done it for the past twenty years is to jumper those terminals on the solenoid, use a Ford remote solenoid mounted in an easy to reach place on the inner fender, or firewall. To disconnect for pulling the engine, etc, just pull the starter cable from the solenoid. The small wire to the original solenoid, of course, now goes to the new Ford solenoid. Easy to get the short cable off the Ford solenoid to pull the starter, or engine. Has worked well for me, for many years. Hope this helps.
Old 07-04-2018, 07:50 PM   #10
GallopinGhost
Ed, I appreciate the info. Do you have a p/n or application for the solenoid?
Brian Carpenter
Stock 1358
