#41 |
Ed Wright 4156 SS/JA |
#42 |
Liked 101 Times in 52 Posts
I think his issue with going to the large drive studs is factory style wheels will not fit over them. Then it requires them to have another set of race wheels to allow for storing/moving the car when the drag tires are off of it rather than a set of stock style wheels.
#43 | |
Liked 184 Times in 113 Posts
Lug Nuts were all fine and not Binding. But several if the Washers were deformed. Installed new Moser Studs and Steel Washers. Cleaned the washer surface, replaced a few Lug Nuts. Going to be more attentive to safety aspects. Will check then with a Torque Wrench before each race. Dan Last edited by Dan Fahey; 07-05-2018 at 02:21 PM. |
#44 |
Dan,
Did you ever measure the wheel center thickness and the lug nut length from washer to end? |
#45 | |
#46 |
#47 |
seriously , a piece of gum? Unbelievable.
#48 |
#49 |
Liked 58 Times in 18 Posts
Now you know why he is having trouble.......
#50 |
Now days they have these things called measuring tools. Surely you have seen a tape measure ? And who uses gum to check valve clearance on a racing engine, because I want to stay away from them.
