Old 07-06-2018, 09:28 PM   #51
Ed Wright
Ed Wright's Avatar
Default Re: Wheel Studs
Originally Posted by racecraft View Post
Now days they have these things called measuring tools. Surely you have seen a tape measure ? And who uses gum to check valve clearance on a racing engine, because I want to stay away from them.
Gum, or even clay. So 1950.
Ed Wright 4156 SS/JA
Old 07-06-2018, 10:09 PM   #52
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
It worked perfectly !
I knew exactly how much tolerance there was!
Pack the gum onto the hole around the half the stud.
Tighten the lugs..remove the wheel and measure the impression.
Just like you do with Cylinder Heads and questionable Valve Clearance.
Plastiguage is used for Measuring Crank Bearing tolerances.
It was simple and effective.
Get over it !
Old 07-06-2018, 11:06 PM   #53
Ed Wright
Ed Wright's Avatar
You THINK you know how much clearance you have.
Old 07-07-2018, 12:25 AM   #54
racecraft
Carry on, you seem to have it all under control. I have evidently been measuring things wrong all this time. Could have saved a lot of money over the years buying useless measuring equipment when I could have just bought a pack of juicy fruit.
racecraft is offline   Reply With Quote
Old 07-07-2018, 01:26 PM   #55
Ed Wright
Ed Wright's Avatar
Yes, wheel studs are one thing, but valve-to-piston? LOL
Old 07-07-2018, 05:59 PM   #56
Dan Fahey
Dan Fahey's Avatar
Yes you have.
Shame on yourself!
Old 07-07-2018, 08:23 PM   #57
Ed Wright
Ed Wright's Avatar
Yes you have.
Shame on yourself!
Says the IHRA Pure Stock "racer". LOL
Old 07-07-2018, 09:24 PM   #58
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
What’s IHRA?? 🤣 pure stock racers think this is easy!!!
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 07-07-2018, 10:27 PM   #59
Ed Wright
Ed Wright's Avatar
If he tries to make an NHRA Stocker out of that thing, he will find the water much deeper.
Old 07-11-2018, 03:45 PM   #60
Bobby DiDomenico
Liked 101 Times in 52 Posts
Get over it !
I was thinking stone age, like a wooden coffee stirrer and a pencil worst case.
You insert it thru the lug nut hole till it stops, mark it and compare to lug nut shank length. Gum????
