Liked 20 Times in 15 Posts
How do you like to rebuild, stock parts/strip kit or revamp with Holley jets?
Liked 263 Times in 68 Posts
I would use stock parts.
John Dinkel 3295 STK |
Liked 108 Times in 29 Posts
I think your fishing for an easy answer. I would say, spend the money (three hundred plus dollars each) and have good builder do three carbs for you. then you can compare the carbs back to back. I could tell you which one picked my car up a tenth, but that would give you our answer. Spend the dollars and do some research on your combination.
#4 | |
Ed Wright 4156 SS/JA |
Liked 5 Times in 2 Posts
I'm sure others might be more willing to share but there are two reasons not to just give an answer. First when it costs you that or more, you aren't very willing to just give that info out. Second and more importantly like was mentioned, you need to try different setups on your combo. One size does not fit all especially at varying elevations because I can guarantee they will behave differently.
5705 F/S 5706 D/SA |
Liked 3,212 Times in 980 Posts
What Ed said....but know that you may have to try more than one to get the best. They simply do not all perform the same even with same Holley jets or the rods. Have used both VanLant and Wahl with success.
Liked 53 Times in 38 Posts
A shame but what they're saying, learn to do it yourself or have a big wallet.
Mike |
#8 | |
Liked 21 Times in 13 Posts
What exactly are you suggesting ? 1 builder do the same model carb 3 different ways, or use 3 different builders ?
Brian Carpenter Stock 1358 |
Liked 312 Times in 175 Posts
Carb builders get comfortable with their own setup and it's unlikely they would build the same style carb 3 different ways. IMO you should gather info and order one built to suit your combo from " the brand name guy " then later after your making laps you can try another one, then another one, and then............
That makes sense. It would be cool to see dyno testing using different center bodies(thinking holleys here) and the same mods. Probably classified info though
