Old 07-21-2018, 04:40 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Mopar tq rebuild
How do you like to rebuild, stock parts/strip kit or revamp with Holley jets?
House of Darts is offline   Reply With Quote
Old 07-23-2018, 12:48 PM   #2
John Dinkel
Liked 263 Times in 68 Posts
Default Re: Mopar tq rebuild
I would use stock parts.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 07-23-2018, 02:38 PM   #3
Demon340
Liked 108 Times in 29 Posts
I think your fishing for an easy answer. I would say, spend the money (three hundred plus dollars each) and have good builder do three carbs for you. then you can compare the carbs back to back. I could tell you which one picked my car up a tenth, but that would give you our answer. Spend the dollars and do some research on your combination.
Demon340 is online now   Reply With Quote
Old 07-23-2018, 07:31 PM   #4
Ed Wright
Ed Wright's Avatar
Why would you not want to give him the answer, and maybe save him $600.00? You could pm him to not offend anybody.
Ed Wright 4156 SS/JA
Old 07-23-2018, 10:39 PM   #5
cyclonebfx
Liked 5 Times in 2 Posts
I'm sure others might be more willing to share but there are two reasons not to just give an answer. First when it costs you that or more, you aren't very willing to just give that info out. Second and more importantly like was mentioned, you need to try different setups on your combo. One size does not fit all especially at varying elevations because I can guarantee they will behave differently.
5705 F/S
5706 D/SA
cyclonebfx is offline   Reply With Quote
Old 07-23-2018, 10:42 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
What Ed said....but know that you may have to try more than one to get the best. They simply do not all perform the same even with same Holley jets or the rods. Have used both VanLant and Wahl with success.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-24-2018, 12:15 AM   #7
Coleydog
Liked 53 Times in 38 Posts
A shame but what they're saying, learn to do it yourself or have a big wallet.
Mike
Old 07-24-2018, 06:46 AM   #8
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
What exactly are you suggesting ? 1 builder do the same model carb 3 different ways, or use 3 different builders ?
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 07-24-2018, 08:23 AM   #9
Hacksaw
Liked 312 Times in 175 Posts
Carb builders get comfortable with their own setup and it's unlikely they would build the same style carb 3 different ways. IMO you should gather info and order one built to suit your combo from " the brand name guy " then later after your making laps you can try another one, then another one, and then............
Old 07-24-2018, 09:31 AM   #10
GallopinGhost
That makes sense. It would be cool to see dyno testing using different center bodies(thinking holleys here) and the same mods. Probably classified info though
Brian Carpenter
Stock 1358
