Old 07-28-2018, 08:37 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Lenco trans
Not sure if this is the right place to ask but there's some knowledgeable guys on here so My question, I looking to put a "used" 4 speed Lenco in my steet strip car and not sure what to stay away from or what to look for.
thanks, Mike
Old 07-29-2018, 01:24 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Lenco trans
my experience with Lenco's is from the distant past . I can tell you that the clutch discs and sprags for early Lencos are not easy to find anymore.
Also setting the towers to give a acceptable shift for street driving could be an issue.
For a ProStreet car it might be livable. ...Definatly has the WOW factor.
Might find more input from the Comp Forum if there are any old timers left on there, Lenco's have been mostly obsolete for at least the last 25 years or more for conventional door cars.
Old 07-29-2018, 11:37 PM   #3
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
The last early Lenco I worked on, I used Ford FMX discs and bored the ID an additional .025. They worked perfect and didn't have to hunt for them. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-30-2018, 12:08 AM   #4
Maverick
Liked 36 Times in 26 Posts
Do you have the Lenco? There are people out there, that have that answers, just go know where to find them. If you got the Lenco, put it in and see what you got. Very durable, and I would call Lenco, they might be able to give you some info. I usually go to certain racers at the track that run them.
Old 07-30-2018, 12:12 AM   #5
Maverick
Racer from division 5 last year won super gas division championship, and he had a lenco 4 speed in his Camaro
Old 07-30-2018, 12:50 AM   #6
Maverick
I usually walk thru top sportsman's staging lanes and see who runs them. Most guys run it behind a convertor. Watched a top alcohol dragster couple of years ago, yearvdown and inspect and put back together his transm. And they showed me what to look gor
Old 07-30-2018, 01:22 AM   #7
Maverick
Sprags can be expensive if you need them, just don't k ow your budget.
Old 07-30-2018, 12:26 PM   #8
Coleydog
Don't have anything yet, I wanna buy once. A lot of good answers so far, should be some good ones still laying around in the attic.
Mike
