Old 08-02-2018, 12:50 PM   #21
CMcAllister
Liked 920 Times in 259 Posts
Default Re: 360 mopar oiling issue
I'm not sure, but they were small. .035 maybe. Slightly more for the heads. I wanted to get oil on the crank and keep it there instead of squirting off in other directions. A lot of oil will come through a .035 hole with 60 PSI behind it. .125" holes in the cam bearings is a number I've seen and that sounds way bigger than it needs to be. .125" x 4 is a big oil leak.
Old 08-07-2018, 10:56 PM   #22
dondon
Liked 10 Times in 5 Posts
dynoed new motor today, made 8 pulls. Pulled oil pan and number 3 rod bearing looked real nice. Happy for the time being.
dondon is offline   Reply With Quote
Old 08-08-2018, 10:14 AM   #23
GTSDart
Good to hear...
GTSDart is offline   Reply With Quote
Old 08-08-2018, 05:02 PM   #24
CMcAllister
We used a System 1 filter. Made it pretty easy to tell what was going on. Easier than pulling the pan to look.
