Old 08-11-2018, 07:57 PM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default Stocker Low Compression Approved Fuel.
Low compression SBC stocker motor, would like to run lowest Octane approved fuel. What would everyone suggest? 92 unleaded Pump gas is not legal at a Divisional Lucas Oil race ?
6380 STK Steve Teeter.
SDT1DYI is offline   Reply With Quote
Old 08-11-2018, 08:39 PM   #2
SDT1DYI
Default Re: Stocker Low Compression Approved Fuel.
Forgot to add, leaded or unleaded for Low compression.???
6380 STK.
Old 08-11-2018, 09:47 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
First choice VP C-11.2nd Sunoco standard 110. Both are leaded fuels.Pump gas is not legal at a NHRA divisional,nat.open or national event. gsa612
Old 08-12-2018, 09:25 AM   #4
Bill Bagley
Bill Bagley's Avatar
Liked 31 Times in 10 Posts
Same recommendation. I've tried both on the dyno and saw no discernible difference.
Bill Bagley
4561 STK
Endeavor to Persevere!
Bill Bagley is offline   Reply With Quote
Old 08-12-2018, 09:46 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Bill,
Is there a jetting or timing difference in the two fuels?
Adger Smith (Former SS)
Old 08-12-2018, 12:22 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Look at
Sunoco 260 GTX Unleaded
VP C10 or VP C20 both Unleaded.
All three are NHRA legal.
D
Old 08-12-2018, 12:44 PM   #7
GTX5877
Liked 20 Times in 9 Posts
Sunoco tech recommends Sunoco 'Surge' as their best low compression fuel at 105 octane over 260 GTX fuel. It is now on the the approved fuel list. Supposed to have some better qualities than 260GTX.
GTX5877 is offline   Reply With Quote
Old 08-12-2018, 01:28 PM   #8
gsa612
gsa612's Avatar
What year,cubic in,comp.ratio is the SBC ?. gsa612
Old 08-12-2018, 02:12 PM   #9
gsa612
gsa612's Avatar
Originally Posted by Adger Smith View Post
Bill,
When Pete had his 80 305 we dynoed Sunoco110,C12,C11 and even tried C25 ($20+ gal.at the time).The C11 was worth about 5,it liked to be 1 step richer on the sec. rod. over the C12 and the 110.The C25 came around after changing timing, jets,rods,moving the cam.In the end it showed a couple of HP over the C11.Some guys were seeing close to 10 on BBC.On the SBC the minimal gains did not justify the cost.So C11 it was! gsa612.
Old 08-12-2018, 02:39 PM   #10
ron mattson
Liked 68 Times in 31 Posts
C11 works well, better than the older
Sunoco supreme, have not tried the newer
unleaded fuels, c25 was a tick quicker but
Expensive as stated earlier would only use for class
or heads up.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
