Liked 759 Times in 379 Posts
pole mounts.
Post your photos. TIA |
Liked 431 Times in 224 Posts
I don't have a photo, but I have this Plattinum Products mount set. One piece to hold the weather sensor unit inside the trailer during transport, and a tube to securely support the bottom of the pole outside the trailer:
https://www.ebay.com/itm/Plattinum-W...sid=m570.l1313 At the top trim of the trailer, above the support tube, I use one of these to secure the top of the pole: http://www.biondoracing.com/product/ALB-QC2-2.html
S/ST 51 S/C 53 |
I found a photo that isn't very detailed but should at least illustrate what I posted above:
S/ST 51 S/C 53 Last edited by Lenny5160; 08-13-2018 at 12:21 PM. |
Liked 627 Times in 156 Posts
Ed, I use 3 of the following, coulda probably gotten by with two... but the Cold War made me a believer in overkill, lol!
https://www.amazon.com/dp/B000CQPANY..._xwECBbZYJH2XC
Pete Lanciers PAL Automotive Racing Stock 7801 |
Thanks for the replies.
Pete, I have 4 of those clamps enroute. I believe they are also the same ones that Altronics sells. I also have these brackets coming that Computech uses and I'm using the same pole... That Platinum Products bracket is trick for transporting the weather station head inside the trailer... ![]() Also found this pole mount which would work too... https://www.shop.flagpolebuddy.com/S...Dia-106961.htm available in 1", 1.5" and 2" Last edited by 1320racer; 08-14-2018 at 08:42 AM. |
Liked 1,982 Times in 597 Posts
I use the rubber ones from Altronics. 2 on the exterior and 2 inside for storage. Easy to use and won’t rust. I store my trailer inside. If you store yours outside in the elements then the rubber ones might break down after a few seasons.
Mike Pearson 2485 SS |
Liked 262 Times in 74 Posts
I have to say this thread has made me get off my butt and finally make a mounting pole for my wind meter. Now mine is just a $50 weather station from TSC cause I’m a poor boy but, as long as it gives me wind speed I’m happy.
Steve Polhill 3520 STOCK, COMP |
I ended up using the brackets that Computech uses/sells, shown in the video below.
Thanks again for the replies. |
