#11 | |
Liked 31 Times in 10 Posts
It was at the tail end of the dyno session and we didn't compare any farther than switching from one fuel to the other, so I don't have an answer to that one.
Bill Bagley 4561 STK Endeavor to Persevere! |
#12 |
Ron, which engine do you run?
Ed Wright 4156 SS/JA |
#13 |
Liked 68 Times in 31 Posts
I ran the 255/350, 295/350, 278/350and now the 1970
lt1 360-325/350
Ron Mattson 5015 STK |
#14 |
Liked 271 Times in 107 Posts
Renegade R11 is a good option also.
#15 | |
Liked 184 Times in 113 Posts
Color: Green Octane (R+M)/2: 98 Research Octane: 103 Motor Octane: 93 Specific Gravity: 0.762 Weight (lbs/gallon): 6.3 Reid Vapor Pressure (PSI): 4.7 10% Evaporation (°F): 182 50% Evaporation (°F): 220 90% Evaporation (°F): 227 Stoichiometric Air/Fuel Ratio: 14.6 Oxygen (weight%): 0 Ethanol (volume%): 0 H/C Ratio: 1.76 Lower Heating Value (Btu/Gallon): 115800 Lower Heating Value (Btu/Pound): 18240 Dielectric Constant: 1.6 Leaded: No |
#16 | |
Color: Light Yellow Octane (R+M)/2: 105 Research Octane: 109 Motor Octane: 101 Specific Gravity: 0.714 Weight (lbs/gallon): 5.9 Reid Vapor Pressure (PSI): 8.0 Initial Boiling Point (°F): 90 10% Evaporation (°F): 125 50% Evaporation (°F): 210 90% Evaporation (°F): 225 Final Boiling Point (°F): 250 Stoichiometric Air/Fuel Ratio: 14.9 Oxygen (weight%): 0 Ethanol (volume%): 0 H/C Ratio: 2.09 Lower Heating Value (Btu/Gallon): 111,975 Lower Heating Value (Btu/Pound): 18,650 Dielectric Constant: -0.2 Leaded: Yes |
#17 |
Liked 456 Times in 148 Posts
Some good info to work with. Ran the new 350 2 barrel combo on pump gas last weekend. 1/8 mile hits only. Divisionals this weekend . Will have C11 in It. Interested in comparing 1/8 performance of 3.50$ gas to 15.00$ race gas. Probably faster on pump gas.
STK. 6380. |
#18 |
Liked 1,001 Times in 276 Posts
Call Jason @ Insinger fuels, he will give you the lowdown on the Surge and any other Sunoco fuels, I have been doing some testing with the Surge for them and he has my info and others on the results.
Jason 5706376081 Duane
Duane Hoven 1342 SS/GT |
#19 | |
Liked 239 Times in 114 Posts
#20 |
An you mix race gas...so long as it done now have ethanol.
Not all tracks carry the same fuel D |
