Old 07-31-2018, 09:02 AM   #21
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Mopar 904 trans pressure
I just recently saw this problem on a customers 360 Drag Pak engine.
It was caught in time before the crank was damaged.
The root cause was not the converter but the converter pilot hub not having adequate clearance and bottoming in the crankshaft .030" before the converter reached the flexplate .
I was able to increase the clearance by using a .125" mid plate as a spacer and then using .125" spacers between the converter and flexplate .
The proper fix will be to machine the pilot hub deeper when the engine is apart for freshening . In this case the crank was a Scat crank , but I checked the depth against a stock 360 and it was within .020".
Converters do not actually balloon with modern shells and reinforcements ,but rather they try to push out of the pump .Excessive line pressure can be a factor, but the key word is excessive
Usually this movement is absorbed by the flexplate ,,but when there is no free movement in the crank pilot hub ,the thrust takes the load.
Old 08-19-2018, 06:21 PM   #22
devo340
devo340's Avatar
Liked 168 Times in 30 Posts
Update; Found the ATI convertor that is in the car is bottomed out in the crankshaft. Have a spare Turbo Action convertor & checked it & had .102 clearance between the convertor snout & the crank. Real close to the problem identified in this thread.
devo340 is offline   Reply With Quote
Old 08-19-2018, 08:06 PM   #23
Bill Grubbs
Liked 564 Times in 66 Posts
Call ATI...their pilots are screw on, and can be bought in differing lengths.
Bill
Bill Grubbs is offline   Reply With Quote
Old 08-20-2018, 02:49 PM   #24
340Cuda
Liked 805 Times in 341 Posts
Mike that is great news.
Old 08-20-2018, 05:46 PM   #25
devo340
devo340's Avatar
Bill
Talk with ATI, they will have to move the lugs on the convertor to get the Clearance that I need.
Old 08-22-2018, 05:18 PM   #26
sugar1366
You should inspect the front pump in the trans. If it was pushing forward on the thrust bearing, then it was probably pushing back on the inner gear of the pump.
Eddie Bolton
sugar1366 is offline   Reply With Quote
