Old 08-26-2018, 09:28 AM   #1
yankees
Default Licensing ?
If I have a Pro/Sportsman Level 4 Type A license (Over 125" Wheelbase) for Super Comp, can this license also be used for Super Gas (Up to 125" Wheelbase)?
yankees is offline   Reply With Quote
Old 08-26-2018, 10:16 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Licensing ?
Regarding Cross Licensing----If I'm not mistaken you will need to do a few runs in a vehicle typical of the vehicle you want to get cross licensed in and make several passes at the appropriate ET for that class. You then must have your application signed off by 2 witnesses that are licensed in or above your new class plus the track manager. Double check the rule book or call any division office for clarification. Good luck
Old 08-26-2018, 01:46 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Here's a link to the licensing rules/requirements -
http://promod.nhra.com/userfiles/fil...egulations.pdf
It might be a good idea to contact your Division Director's Office to make sure you are getting the most current information.
Lew Silverman #2070
"The Wagon Master" N/SA
