Old 08-28-2018, 08:16 PM   #21
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: quadrajet 455ho
Originally Posted by Jeff Stout View Post
I always thought the opposite. Unburned fuel from 2 step going out exhaust and making a rich condition. My bracket car has a O2 reader and on 2 step it is rich and gets right by second gear shift. Yes on to big primary with no rods.
In a production car , when the engine misfires the O2 sensor reads lean , and then starts to add more fuel to correct . Most production calibrations will only allow so much correction , and once it reaches that limit , it sets a code . A misfire is similar to what a two step does only more controlled . I am surprised your engine reads rich when on the two step . Hopefully a few more folks will chime in with their experiences .
As far as running as big a jet with no rods , I agree , too big , but remember that this particular carb has the POE system , which adds even more fuel into the primaries at WOT . He might have to put a very small primary jet , or reinstall the power piston and primary rods .
ss3011 is online now   Reply With Quote
Old 08-28-2018, 10:15 PM   #22
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
^^^^ Read an article on one of the Burton firebirds.They claim to run a 61 pri.jet,it does not say if that's in Denver or...So say if you ran at sea level and went to a 63,that would be 11 steps leaner than the 74 that's in it now.You would think if it's that far off it would be just flat off the line.What does the car 60' 330' and ET. gsa612
Old 08-29-2018, 03:30 AM   #23
gearhead63
Liked 13 Times in 4 Posts
when on the 2 step afr is 18-19 but afterreleasing the 2 step afr goes from 10.5-12 just before shifting to second gear. poe system blockt. best 60 foot 1.39 best et 10.69 in e/sa should change to 69 pri jet for the next race and but a gopro camera under the hood over the carburator.
gearhead63 is offline   Reply With Quote
Old 08-29-2018, 07:55 AM   #24
ss3011
ss3011's Avatar
You may not be too far off , your et and 60 ft is pretty darn good . Tweeking the primary jets will let you see what the combo wants . Also , my 455 HO wants around 40 degs of timing , what are you running ?
Old 08-29-2018, 09:56 AM   #25
gearhead63
it likes 36-37 degrees best but we are using vp motorsport 109 are not allowed to use leaded fuel here in Europe. our goal is go 1.1sek under index to be a little faster than the other e/sa cars here.
Old 08-29-2018, 10:28 AM   #26
ss3011
ss3011's Avatar
The VP 109 has plenty of octane for your engine , I would warn you that because that fuel has no anti corrosion additives it will rust the valve seats . You would need to fog WD-40 or some other spray lube into the intake after you are done racing for the weekend .
Old 08-29-2018, 07:22 PM   #27
gsa612
gsa612's Avatar
What is the elevation of the track you run at ?. gsa612
Old 08-30-2018, 02:37 AM   #28
gearhead63
the track were we ran 10.69 is 682 ft over sea level and we had 1700 ft of air.
