Old 08-27-2018, 01:29 PM   #1
Rick Kolber
Liked 32 Times in 13 Posts
Default Stranded in indianapolis
Need advice for a reputable diesel repair service in Indianapolis that will work on 02 Dodge 2500 diesel. Truck just stopped running. Has p pcu and p ECU codes, no numbers after. Thanks for any responses.Dealer says it will be two weeks before they can look at it!
Rick Kolber is offline   Reply With Quote
Old 08-27-2018, 01:35 PM   #2
Chuck Westcott
Chuck Westcott's Avatar
Default Re: Stranded in indianapolis
Call Fleece Performance Diesel- Brownsburg - they might help
..317-286-3573
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 08-27-2018, 02:07 PM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
..317-286-3573
Fleece is awesome. They fixed a friend's Dodge diesel 1-ton at IRP just a couple of years ago.
Jim Kaekel 3836 STK
Old 08-27-2018, 08:42 PM   #4
Rick Kolber
Called Fleece and sounds reasonable but if not easy fix could be 3 weeks
Old 08-28-2018, 08:01 AM   #5
Hacksaw
Liked 312 Times in 175 Posts
Rick: Curious as to what problem your truck has. Please post results as I have an almost identical tow unit. Hope it turns out to be an easy fix and good luck with it.
Old 08-28-2018, 08:34 AM   #6
Scott Loge
Liked 145 Times in 32 Posts
Give us a call, we will help any way we can.
The Loge’s
925-584-8402
Scott Loge is offline   Reply With Quote
Old 08-29-2018, 10:34 AM   #7
Phillip marvetz
Phillip marvetz's Avatar
It's usually the injection pump on those trucks. Couple thousand dollars will fix it right up.
2009 V/SA Record Holder
Old 08-31-2018, 08:36 AM   #8
Rick Kolber
I want to thank all the people that helped or offered help the Irvings, Mike Loge, Biil Bagley, Bruce Gibson and others. It came down to bad gas and thanks to Mark at Diesel and Turbo in Indianapolis for getting it in and out and on the road again. Now to concentrate on racing. I made the field!!
Old 08-31-2018, 04:10 PM   #9
Bill Bagley
Bill Bagley's Avatar
Liked 31 Times in 10 Posts
That's great news Buddy! We know you meant 'bad fuel', and that's ok. You're a gasoline guy - Right? Holler if you need help shuffling vehicles to get things back in order.
Bill Bagley
4561 STK
Endeavor to Persevere!
Bill Bagley is offline   Reply With Quote
