Old 05-04-2018, 05:34 PM   #1
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Default Hercules 225/75r15 12 Ply
Been running Maxxis 8008 10 ply load range E. Would like a little more tire but cannot go to 16" due to spread axle and fenderettes on my ATC trailer.
Hercules has a 12ply load range F in the 225/75r15.
Has anyone run this tire? It is fairly new so not many reviews.
https://www.herculestire.com/tire-de...les/H-901%20ST
NSSGTO is offline   Reply With Quote
Old 05-14-2018, 01:33 PM   #2
NSSGTO
NSSGTO's Avatar
Default Re: Hercules 225/75r15 12 Ply
215 views and no input. Wish there was more info on these.
Old 05-14-2018, 06:54 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Hercules Tire has been making products in Findley, Ohio as part of the Cooper Tire and Rubber Company for many years, so they are are (or should be) a reputable brand. They have a large dealer network, so maybe that would be a good place to ask about their warranty/replacement policy.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-14-2018, 07:14 PM   #4
jmcarter
jmcarter's Avatar
The Hercules specs show that size as 10 ply, not 12 ply and with the same load rating as Maxxis in that size. I’ve had good luck with Maxxis and since I’m restricted by size think I’ll stick with what’s worked for me. Goodyear? Not so much...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-14-2018, 11:06 PM   #5
NSSGTO
NSSGTO's Avatar
You need to look again, the link I pasted
95135 ST225/75R15 12ply 121/118 F 3200@95 2910@95 28.17 47.44
Tire Size ST225/75R15/12
Load Index 112/118
Speed Rating L
Load ID F
Sidewall BW
Min Rim Width (in) 6
Max Rim Width (in) 6
Overall Width (in) 8.98
Overall Diameter (in) 28.17
Old 08-07-2018, 07:41 AM   #6
ken robinson
Liked 224 Times in 87 Posts
Seams like a good trailer tire did you buy them ?
Old 09-05-2018, 02:46 PM   #7
ken robinson
I got one of those tires as a spair . It's a heavy duty tire & you need a 6 wide rim .
Old 09-05-2018, 06:50 PM   #8
Demon340
Liked 108 Times in 29 Posts
We installed the Hercules 235/85 r16 on our trailer Which was same size as the trailer manufacturer recommendation . Got a good deal, but found that the side walls had more of a buldge and had to beat the crap out of the inner fender to keep from rubbing.
Demon340 is offline   Reply With Quote
Old 09-17-2018, 02:31 PM   #9
lareagle
Liked 25 Times in 11 Posts
Has anyone ever used a heavy ply truck tire in place of the trailer tires ?
Tire dealer said the speed rating is about 65 mph on trailer tire and were
running right on edge that could make to much heat on tire.
Larry
lareagle is offline   Reply With Quote
Old 09-17-2018, 08:55 PM   #10
Demon340
Larry
Never heard of a max 65mph on trailer tires. We run about 10 under the speed limit in Colorado and Utah; except for one tire blow out coming down Vail pass (that wasn't the tires fault) just sucky Colorado roads; we havent had any other problems with trailer tires.
I have had more sway with truck/passenger tires when towing.
