Old 09-17-2018, 12:18 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default plastic printing
i was watching a video on plastic printing. Ha anyone used one of these tro make light weight brackets or other parts?
Old 09-17-2018, 09:54 AM   #2
SSDiv6
Liked 1,603 Times in 583 Posts
Default Re: plastic printing
You must be talking about 3D printing.
There are already a few parts out there, including intake manifolds that have been manufactured from Nylon. There are also printers that will create metal parts from powered metal.
Old 09-17-2018, 11:02 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The trick with 3D printing of custom parts is that they need to be designed in CAD files. That requires fairly expensive software and a good deal of skill to prepare the file to feed the printer. Couple of grand to set this up for a bracket lighter but not as strong as 6061 aluminum. I'd much rather have a mill and lathe.
Dale Shearon
68 Mustang 6394
Old 09-17-2018, 12:45 PM   #4
David Lee
there is sw that is vert very good and for free, one is made by the makers of autocad. while i would love to own a nice lathe and mill, the cost and space required would be prohibitive.
Old 09-17-2018, 12:54 PM   #5
Ben Holt
Liked 112 Times in 40 Posts
We have one and have been making quite a few parts with it. It is perfect for setup and/or temporary parts. We have made quite a few sets of runners for our comp car this year, we have even been running the runners down the track all year. Much cheaper than the billet aluminum runners we had made before...
That being said, you do need to be able to draw the part up, but that merely takes the program and some practice
Ben Holt is offline   Reply With Quote
Old 09-17-2018, 01:15 PM   #6
Chad Fergen
Liked 24 Times in 12 Posts
We have 5 of them at work and they can make about anything you want but like said, someone needs to draw them up for you first. Ultem is one of the stronger materials you can get for that but its not as strong as aluminum.
Chad Fergen is offline   Reply With Quote
Old 09-17-2018, 05:05 PM   #7
David Lee
can you tell me what printers you are using?
Thanks
Old 09-17-2018, 06:18 PM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: plastic printing
I couldn't help but wonder if there is a compatible material that could be used in 3D printing to make replacement Thermoquad fuel bowls.
LOCOMOTION Racing
Old 09-17-2018, 06:24 PM   #9
David Lee
find out what plastic was used and would be more than happy to investigate it.
Old 09-17-2018, 06:31 PM   #10
Myron Piatek
Post Re: plastic printing
I'll ask/check around. Don't know if it's accurate, but I've heard it referred to as "phenolic".
There is a source for small primary bowls for under $150, which I don't know if they are still being manufactured or there is just a large overstock. But no source for big primary bowls that I'm aware of.
LOCOMOTION Racing
